Sponsored by:
Sponsored by: CARiD
Tunable muffler replacement screws!
Old May 4, 2003
krafty420's Avatar
krafty420 is an unknown quantity at this point
Ok, heres the deal. I have a OBX Type-R Racing Catback exhaust with the tunable muffler. It has 2 allen bolts to ajust the air flow and "tune" the muffler. I was ajusting the muffler yesterday and completely forgot to re-tighten the allen bolts before I took off, and guess what, no more allen bolts. Now the ajustable metal disc inside the muffler is just rattling around loose inside the muffler. I managed to get the disc back where it belongs and secure it from falling back into the muffler with a screw that doesnt quite fit, however is rattles like crazy because the screw doesnt screw in all the way to tighten it back down! Anyone know where I can find some replacement allen bolts or even screws that match up to the thread pattern to fix this. Thanks for any suggestions.
-krafty420
Old May 4, 2003
Bartkat's Avatar
You might take drill bits and use them as gauges. Try till you find a bit that will barely stick in the hole, then get a metric screw the size of that bit. Maybe an assortment of srews close to that size and try till you find the ones that fit.
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
thesushiboy
Apr 12, 2015 02:54 AM
Foom
Dec 6, 2001 01:11 PM
SneakerPimp
Nov 25, 2001 09:53 PM
colombianDXcivic
Nov 8, 2001 12:14 AM
