Sponsored by:
Sponsored by: CARiD
Venom400 or JET?
Old Mar 21, 2003
sandman1011's Avatar
sandman1011 is an unknown quantity at this point
Venom400 or JET?
Which one is better? I don't know much about Jet, except that you ship your ECU to them and they reprogram it for you. And from what I've read, the Venom 400 pretty much only allows you to get to WOT quicker, and it seems that people are 50/50 about whether it even really helps or not. I have a V-AFC, although I haven't installed it yet b/c I'm waiting for Apexi to figure out the V-tec wiring for our cars. But considering that, would that make the Venom 400 kind of a moot point since I'll already be to adjust the fuel curves with the V-AFC? Sorry for sounding like an idiot, but I'm kinda clueless when it comes to ECU's.......
Old Mar 21, 2003
Bartkat's Avatar
Venom 400 doesn't do much. It may allow a bit more initial timing advance at 2/3 to full throttle by fooling the ECU. I have one, and it maybe takes 0.1 sec. off the 1/4 mile times. It does seem to give a bit more pep at 60 to 80 MPH about time that the Vtec kicks in.
The V-chip sounds better to me, since they claim to have curves for different levels of mods. I think it will also eliminate the rev limiter. For what that's worth.
Word is that the VAFC problems have been worked out. I don't have first hand experience on this though. All I've seen from VAFC is that when you lower the VTEC engagement point, all you get is a spike in the power curve and that is of no benefit. I suppose if you have other mods, the fuel map and ignition curve adjustments might be helpful.
There used to be some threads around here on most of the above stuff.
Old Mar 21, 2003
CivicSouldjaEX's Avatar
So many choices, what to do, what to do?
Old Mar 21, 2003
Bartkat's Avatar
If you already have VAFC, check with Apexi and see if they don't have that wiring problem solved.
My personal thought has been to buy a used ECU, and send it off for a chip job. That way I could run stock and compare to the Jet and decide wich way I want to go. Also if selling the car could put the stock back in and then sell the Jet ECU separately.
Old Mar 21, 2003
Distinctive's Avatar
Smell My Face!!
i have the 400 on my 90 integra and it suck not worth the $$.
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
Uan
Aug 23, 2015 03:03 AM
02CarbonCivic
Jun 26, 2002 03:31 AM
jagradar
Mar 6, 2002 09:35 PM
nongv
Feb 10, 2002 07:38 PM
