k & n installation
might as well man. as soon as you install it your gonna want to reset the computer, which is simply dont be disconnecting the (-) battery terminal for 15 minutes. as you reset the computer, the new part will be better utilized by allowing the computer to adjust to the better airflow.
u will need to reset your ecu anyways by taking the battery cables off, you need to do this so your engine will recognize the air flow to the engine.
Click here to see how to reset
injen
injen
It's a good safety practice to disconnect. You could accidentally short something and start a fire, or your car could start and run over you, or any number of things could happen while working under the hood.
There is a reset procedure in the owner's manual. It seems mainly to take the ECU back to the best settings for emissions and maybe fuel economy. Then the ECU picks up on what's going on from there.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
