Sponsored by:
Sponsored by: CARiD
!!HELP ME!!!
Old Feb 27, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
!!HELP ME!!!
i jus instaled remote start and keyless entry the door locks and horn work perfectly the only thing is i hooked up to wrong wire for parking lights does anybody know which wire is for parking lights in steering shroud???also when i hit the start button it cranks but doesnt turn over. i connected all my wires corectly except for the tach wire i think does anybody know which wire in the back of the gauge cluster is the tach signal, honda told me blue/yellow but thats not working.....i thought it was transponder but then i put my key next to the igntion while hitting start button and still it cranks but doesnt turn over.. so i need colors for tach signal and colors for parking lights in the steering shroud.
thanx for your help. and please dont tell me to lok in the diy i printed that chart out 2 times.
riley
rijowysock@aol.com
Old Feb 27, 2003
MSoft's Avatar
MSoft is an unknown quantity at this point
Crank but dun turn => Grounding.
Old Feb 27, 2003
Macko's Avatar
Macko is an unknown quantity at this point
What do you mean it cranks but doesn't turn over? did you overide the immobilizer system?
Old Feb 28, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
i hooked the ground of immobilzer up to the brake reset of system as told by a friend. im thinking it might be that but i held my key next to ignition and tried it and it still didnt start..... so im thinking maybe my tach connection was wrong cause honda told me it was the blue/yellow out of green but my friend says its a sea green or light blue out of blue drawing.... when i hit start it acts like if you have no gas it cranks but doesnt turn car on. today after i go to a doctors appointment im gonna go into the tach finder mode and check to see if it's sensing the tach. and then if it does i'll try again and mess around with imobilzer if that doesnt work.... any more suggestions as to whats wrong?
riley
also what do you mean about grounding if it was a ground problem then my keyless entry woudlnt work as well but it does work.
Old Feb 28, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
also would it make a difference if i used the valet key inside transponder box or should i have used the spare black key??? thanx everybody for all of your help.
riley
Old Mar 1, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
so does anybody know the correct color for the parking lights? in the steering shroud? and also the correct color for the tach sensor behine the gauge cluster?
thanx
Old Mar 1, 2003
Bartkat's Avatar
Pull down the fender liner and look at the wire that goes to the parking light. I believe it's blue with maybe a red circular striping. Should be the same color going to the switch.
