Sponsored by:
Sponsored by: CARiD
Distributor cap and rotor
Old Feb 7, 2003
astr033's Avatar
astr033 is an unknown quantity at this point
I was under the impression that 7th Gen Civics don't have distributors. The service advisor at my dealership says otherwise. I asked him why it said "inspect distributor cap and rotor" under the 20,000-mile service for 2001+ Civics. He said that there is a distributor cap or something like that. I asked, "Are you sure? I thought that vehicles with direct ignition don't have distributors." He just looked at me. Then I felt stupid because maybe I'm wrong. After all I don't know that much about cars. So what's the scoop? Am I being charged for something that doesn't exist in my car? Or is there some kind of distributor type thing in our Civs?
Old Feb 7, 2003
bobbyd's Avatar
bobbyd is an unknown quantity at this point
distributor-less ignitions are really just electronic computer controlled distributors.
Old Feb 7, 2003
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
The 7th gen Civics use coil packs instead of distributors and rotors. Your service advisor is a dumbass.
Old Feb 7, 2003
Bartkat's Avatar
Ask the guy if he replaced and gapped the points and set the mechanical timing advance too. [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 7, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
couldnt have said it any better htowncivicEX [IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 7, 2003
Grey's Avatar
DIY King
A distributor distributes the high voltage current to the spark plugs. Hence the name. There's one ignition coil in such a system. With our cars there's an ignition coil per spark plug. The ECU simply tells each one when to fire, so there's no such thing as a distributor in our cars. Your service advisor is either hella stupid, or wanted to make some extra money off of you because of the 20,000 mile service. BTW, I won't be going to mine. I'll do everything myself. I hate dealerships. They're dishonest and money hungry and they take their time to get things done wrong! [IMG]i/expressions/face-icon-small-nono.gif[/IMG]
There are exceptions, but stories like these enforce the stereotype that I believe to be true.
Old Feb 7, 2003
RedDragon333's Avatar
Quote
[hr]Originally posted by: Grey
There are exceptions, but stories like these enforce the stereotype that I believe to be true.[hr]
good point, this is why i searched and searched for a friend in a dealership...hookups and honesty
Old Feb 7, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I dont know if this is true, but The cam gear on our cars has 4 notches on it, and there is a sensor that reads the notches as it spins, I think this is what tells the ignition coils to fire, can anyone verify this....
Old Feb 9, 2003
Bartkat's Avatar
I think that tells the ECU the valve/crank postion and then the ECU tells the coils to fire?
Old Feb 9, 2003
dru106's Avatar
ThE CoRRupToR
Our cars are coil on top of sparks and they fire by the ECU. There is no rotor or distributor cap. Its computer controlled.
Old Feb 9, 2003
Bartkat's Avatar
PLAY PEEBALL
Old Feb 10, 2003
IDQcivic's Avatar
Quote
[hr]Originally posted by: Bartkat
I think that tells the ECU the valve/crank postion and then the ECU tells the coils to fire?[hr]
yeah but something needs to tell the ECU when to fire the ignition depending on which cycle the engine is in, I think the cam gear is what does that because of that sensor that i mentioned, the spark needs to fire at the correct time depending on where the cam is and how the valve ares opened or closed, nothing electrical can just guess this because it needs to be very precise. I know we don't have a distributor but I think the cam gear acts like one so it knows when to fire each coil.... later...
Old Jul 3, 2003
nopher2's Avatar
nopher2 is an unknown quantity at this point
it also may have been a dealer standard form. i know sometimes, those 20,000 miles forms are all standard for every car. just cause it says it doesn't necessarily mean they did it or charged you for it.
and your service advisor knows nothing about what they did to the car in most cases. he just tells you what he knows (which obviously isn't much)
Old Jul 3, 2003
nopher2's Avatar
wow, i just noticed that post is SUPER old...oh well
NaturalSelectio
Sep 6, 2015 06:59 PM
rainman15
Sep 6, 2015 11:10 AM
tooly145
Sep 5, 2015 01:05 AM
NROD315
Sep 4, 2015 09:22 PM
Bman2212
Sep 2, 2015 11:49 AM
