Sponsored by:
Sponsored by: CARiD
Installed OEM FOGS - Evaluation and question...
Old Jan 29, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
I installed my OEM fogs myself. Look great, just wondering how they should be adjusted? Seems that I can hardly see any light from the drivers seat at night with the fogs on alone, unless i SIT UP really high, and even then its minimal. So i maxed out the adjusting screw, it helped a little... any tips on how to get them aimed a bit higher? I just want to have them pointing almost straight.. but down a bit. The cutoff beam and side illumination is EXCELLENT... rivals a projector. RAZOR sharp.
Old Jan 29, 2003
go02civic's Avatar
go02civic is an unknown quantity at this point
how much did u got the oem foglights for? and i heard they crack pretty easy is that true.
Old Jan 29, 2003
Wanger's Avatar
Wanger is an unknown quantity at this point
Quote
[hr]Originally posted by: go02civic
how much did u got the oem foglights for? and i heard they crack pretty easy is that true.[hr]
no, they are actually made of materials equal to if not stronger than aftermarket fog lights.
Old Jan 29, 2003
BlkCivicAngel's Avatar
BlkCivicAngel is an unknown quantity at this point
Wheres the pics?
Old Jan 29, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
the one that crack easy is the oem REPLICA fogs, mine cracked, but i fixed it
Old Jan 29, 2003
SQCivic's Avatar
SQCivic is an unknown quantity at this point
The OEM fogs do crack very easily, I have had two sets already and got tired of spending money on the OEM replacements so I got the OEM replica ones. Best way to protect them is to buy some type of protective covering and cut out a piece to cover each light. Here is a link to the stuff...
X-Pel Protective Coverings
Old Jan 30, 2003
bluestreak's Avatar
bluestreak is an unknown quantity at this point
Did you use the headlight covers, and also how is it to apply?
BootyDo
Jul 7, 2015 06:06 AM
hatch90
Jul 5, 2015 01:17 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
klam
Nov 15, 2001 05:30 PM
