Sponsored by:
Sponsored by: CARiD
The VAFC post
Old Dec 25, 2002
S2000man01's Avatar
O RLY
The VAFC post
Alright, I've seen a lot of debate over this issue, and installing a VAFC in a 7th gen. Some say it won't work, others say it will.
The people I would like to respond are those that ACTUALLY HAVE the VAFC installed. I've read posts where people were able to get it to work in their 7th gen. If I remember correctly, it's because Apexi was able to get the wiring correct finally.
So if you have it, how did you get it to work? Was it simply a matter of waiting til apexi got the proper wiring schematic? What's the deal? What kind of gains were you able to get with tuning??
Old Dec 25, 2002
HondaLuver's Avatar
Its a celebration bitches!
I got it to work by the proper wiring schematic that apexi put out. every thing works right except the check engine light that comes on. i set the v-tec at 4800 and it pulls nicely. i think the way to get the check light off is to tune the air fuel right. i still need to tune mine, i am not sure what to do on the 4 diffrent setting we need to put it on. the high, low, and the settings of the rpm for the 8 stages.
hey s2000man, do you think this will work on your s2000?
Old Dec 25, 2002
Hwoody77's Avatar
Hwoody77 can only hope to improve
Ok, the V-AFC does work. I installed it myself, and it took about one hour. To see where I installed it look below...
Everything on the V-AFC works fine, the VTEC portion works fine, the air/fuel portion works fine(I know because I have an Air/Fuel Gauge).
You can set the VTEC at any point, set at anything above 4500 RPM's, the VTEC crossover point kicks in very hard. Harder then your average B16(DOHC VTEC).
It looks very cool. The only problem with it is the Check engine light problem. To combat this I drive for a few minutes then reset the ECU, and the check engine light goes away. That is the only thing we have to overcome, then the V-AFC will be working fine. I really hate the fact that, that light comes on.
Old Dec 25, 2002
S2000man01's Avatar
O RLY
Quote
[hr]Originally posted by: HondaLuver
hey s2000man, do you think this will work on your s2000?[hr]
Yes, apexi has a VAFC application already for the S2000. But it's not something I'd buy, unless I had some mods.
Old Dec 25, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
This is weird- the D series VTEC engagement point is not as high as the B series (ie mid 5000's), so I dont see any gain of using the VAFC other than for fuel ratios...stock engagement is what, 4600 or 4800- so whats the point?
Quote
[hr]Harder then your average B16(DOHC VTEC).[hr]
I doubt that...
Old Dec 25, 2002
Shlomo's Avatar
Shlomo is an unknown quantity at this point
so your saying that when the check engine light turns on you just have to reset the ECU. (Disconnecting the battery for 10 min., then running the car for like 5 min.) Then the light will turn off for goodl?
Old Dec 25, 2002
Hwoody77's Avatar
Quote
[hr]This is weird- the D series VTEC engagement point is not as high as the B series (ie mid 5000's), so I dont see any gain of using the VAFC other than for fuel ratios...stock engagement is what, 4600 or 4800- so whats the point?
Quote
I doubt that... [hr]
Well, in our D series motor, the VTEC actually engages at about 4k. The reason for a B series to have a higher crossover point is because it has a higher redline, Honda decided that since we are not as performance oriented stuck us with a lower engagement point and a lower redline(There are other reasons). It's cool to be able to adjust your VTEC crossover point, dosen't mean we gain, but VTEC crosses over A LOT harder.
Neo, I've driven, a stock 99 SI, a 99 SI with an intake, a RSX type S w/ I/H/E, and a EG hatch w/ a worked B16.
I've ridden in a 2000 Prelude with a decent amount of work, a LS/VTEC Integra, a Supercharged 00 SI, a 98 NBW ITR, so I know how VTEC crossover in a DOHC is.
Trust me when I say it kicks in just as hard as some of the cars I listed. But I know you don't believe me, that's why in a few weeks I'll put up a video.
Old Dec 25, 2002
NeoMagus's Avatar
Quote
[hr]Well, in our D series motor, the VTEC actually engages at about 4k. The reason for a B series to have a higher crossover point is because it has a higher redline, Honda decided that since we are not as performance oriented stuck us with a lower engagement point and a lower redline(There are other reasons).[hr]
I know. I had a VAFC on my EM1.
Quote
[hr]I've driven, a stock 99 SI, a 99 SI with an intake, a RSX type S w/ I/H/E, and a EG hatch w/ a worked B16.I've ridden in a 2000 Prelude with a decent amount of work, a LS/VTEC Integra, a Supercharged 00 SI, a 98 NBW ITR, so I know how VTEC crossover in a DOHC is.
Trust me when I say it kicks in just as hard as some of the cars I listed. But I know you don't believe me, that's why in a few weeks I'll put up a video. [hr]
Then somethings wrong with your butt dyno if you believe a single cam 127hp motor is pulling harder than a B, H, or K series motor that youve driven. But hey whatever man if it feels good for you then
Old Dec 25, 2002
S2000man01's Avatar
O RLY
Quote
[hr]Originally posted by: NeoMagus
Quote
Quote
Then somethings wrong with your butt dyno if you believe a single cam 127hp motor is pulling harder than a B, H, or K series motor that youve driven. But hey whatever man if it feels good for you then [hr]
A butt dyno tells me that an altima pulls a hell of a lot harder than my car.
But run them side by side, and you see the butt dyno lies.
I think that's what NeoMagus is trying to say.
Old Dec 25, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
can someone please e-mail me the most current wiring instructions, I cant seem to access apexi's website. I'll need the newest one that allows the vtec controller to work. I guess the older instructions had some wires that were not in the manual. Thanks
Old Dec 25, 2002
Hwoody77's Avatar
Quote
Quote
Quote
[hr]I've driven, a stock 99 SI, a 99 SI with an intake, a RSX type S w/ I/H/E, and a EG hatch w/ a worked B16. I've ridden in a 2000 Prelude with a decent amount of work, a LS/VTEC Integra, a Supercharged 00 SI, a 98 NBW ITR, so I know how VTEC crossover in a DOHC is.
No, your mis-understanding me. First, what I mean to say and what I have implied is that the VTEC crossover point in our cars(The point it actually crosses-over, not the pull before or after, just the moment it kicks in), is almost as audible as in a B-series, but you can feel the VTEC crossing over just as hard as in a B-Series.
Old Dec 26, 2002
Wanger's Avatar
Wanger is an unknown quantity at this point
Quote
[hr]Originally posted by: Shlomo
so your saying that when the check engine light turns on you just have to reset the ECU. (Disconnecting the battery for 10 min., then running the car for like 5 min.) Then the light will turn off for goodl?[hr]
ttt for good question. i would like to know if this is true and/or how to overcome this light problem
thx in advanced.
Old Dec 26, 2002
chefjnr's Avatar
[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
PLEASE someone tell me where I can get the latest wiring diagram to get the vtec controller working!! My unit came with a old manual and is of no use
Old Dec 26, 2002
Hwoody77's Avatar
The check engine light will come on anytime you turn on your car after leaving it for a while, I believe this can be changed by putting a switch to your VTEC wire, which I will be doing and keeping you guys updated.
Apexi-usa.com, has the wiring diagram there.
Old Dec 26, 2002
Hwoody77's Avatar
Merry Christmas!
Click here for wiring diagram!
Old Dec 26, 2002
Hwoody77's Avatar
Also, use this in conjunction with what I have sent you...
Click here!
Old Dec 27, 2002
DRJ's Avatar
DRJ
DRJ is an unknown quantity at this point
Correct me if I'm wrong, but isn't the whole point of VTEC adjustment so you can tune when the cam changes from the low rpm profile to the high rpm profile when the low rpm profile begins to leave it's powerband? If that's the case then wouldn't the ideal situation be to tune the VTEC engagement point at the peak of the low rpm profile, therefore minimizing the jolt you feel when VTEC engages due to the fact that the profile switch takes place before the low rpm profile begins to lose power?
Old Dec 28, 2002
Wanger's Avatar
Quote
[hr]Originally posted by: DRJ
Correct me if I'm wrong, but isn't the whole point of VTEC adjustment so you can tune when the cam changes from the low rpm profile to the high rpm profile when the low rpm profile begins to leave it's powerband? If that's the case then wouldn't the ideal situation be to tune the VTEC engagement point at the peak of the low rpm profile, therefore minimizing the jolt you feel when VTEC engages due to the fact that the profile switch takes place before the low rpm profile begins to lose power?[hr]
good theory, but i personally want to feel that jolt when vtec engages. and the low rpm profile would not lose power because right before you think it would, it switches to the high rpm profile.... you know what i'm getting at?
Old Dec 28, 2002
DRJ's Avatar
DRJ
That's just it though...the larger the jolt, the longer the engine has been on the low rpm cam profile when it should have switched. If you tune the car correctly, you don't get both the jolt and the increased power.
My point is that you can increase the "kick" of VTEC, but usually the end result is a loss of midrange power, which IMO, is bad.
Old Dec 28, 2002
Hwoody77's Avatar
Quote
[hr]Correct me if I'm wrong, but isn't the whole point of VTEC adjustment so you can tune when the cam changes from the low rpm profile to the high rpm profile when the low rpm profile begins to leave it's powerband? If that's the case then wouldn't the ideal situation be to tune the VTEC engagement point at the peak of the low rpm profile, therefore minimizing the jolt you feel when VTEC engages due to the fact that the profile switch takes place before the low rpm profile begins to lose power? [hr]
Yes, but, like Wanger said, I like the harder jolt, plus who races below 4k RPM's?
Old Dec 28, 2002
mohawkboom's Avatar
Vtec is pretty much designed for one thing... Balanced power...
Low end torque, and high end torque..
If the cam profiling remained the same as the low RPM setting you'd start to lose torque after abour 5000rpms and your HP would level out instead of rise..
the DX/LX's actually have more midrange power than EX's because of their cam profiling.
For racing applications VTEC is useless as yu'll always be in the agressive cam mode..all it would do is allow for a relatively smooth idle..
Great for daily drivers though...good for fuel economy and getting around...and good for some extra fun when you get the engine revving up.
In the new civics VTEC accounts for about 5HP, the higher compression ratio does the rest.
Old Dec 29, 2002
mrdan4548's Avatar
mrdan4548 is an unknown quantity at this point
so i dont see how this post is helpin out. Did anyone find out how to keep the check engine light from comin on or not? Or why it comes on at all?
Old Dec 29, 2002
Wanger's Avatar
Quote
[hr]Originally posted by: mrdan4548
so i dont see how this post is helpin out. Did anyone find out how to keep the check engine light from comin on or not? Or why it comes on at all?[hr]
just be patient, the only solution right now is to reset your ecu to get rid of the engine light temporarly. just assume that there isn't a fix till someone have posted one..... duh
Old Dec 29, 2002
RiceBuRNeR's Avatar
Turbo Member
Mine works great on controlling the fuel, but I throw a checkengine light If I have the VTEC point adjusted and after a while the dar wont got over 4000 RPMs
Old Dec 29, 2002
IronFist's Avatar
How does adding a VAFC improve your:
0-60mph times?
1/4 mile times?
50-70mph times (for passing and stuff)?
These are what would determine if I buy one or not.
Good thread, btw.
IronFist
Old Dec 30, 2002
Wanger's Avatar
heres something about check engine light on apexi's website.
Q: VAFC: I have finished installing my VAFC but whenever I drive my car around, the Check Engine light comes on.
A: 1. Make sure that the VTM signal wire has been connected. This wire must be conected on all US spec Honda's. Please refer to the Documentation section of this website.
2. If the settings on the VAFC under wide and narrow throttle have been set beyond +12~14% at any point, it will cause the ECU to believe that the car is under boost. This will trigger the MAP sensor error.
3. Make sure that the pressure sensor type is set to 6 IN and 6 OUT. This can be adjusted on the Sensor Type menu of the unit.
try that out, see if that helps......
Old Dec 30, 2002
nongv's Avatar
nongv is an unknown quantity at this point
hey Hwoody77, do you have a diy on how you mounted the vafc? is it just for coupe?
