Sponsored by:
Sponsored by: CARiD
APC 7443 LED's dont' work!
Old Dec 22, 2002
JoeyP's Avatar
JoeyP is an unknown quantity at this point
Here's what I wrote to the company, after neither bulb lit up, leading to me getting my multitester out to diagnose the problem....
"There are 4 leads total coming into the
bulb apparatus, with 2 going to the same place on the circuit board, and the
other 2 going to individual resistors. The latter 2 are the leads that concern
me. They each have a resistor or two and are then connected to either the LED
ring or the middle LED. However, they are also soldered together (in both the
bulbs I bought). When I covered up one lead with electrical tape and plugged
it in, the parking light in the middle would work. When I covered up the other
lead, the outer ring would work when I turned the turn signal on. However,
having both leads exposed (connected to the harness) would seem to me to cause
a short.
When I plugged it in with all leads attached, it got warm (and no LED's lit
up). After a while, the first resistor going to the middle LED burned up
(turned brown). This is because of the short after the resistor, correct?
I believe this was put here to keep the resistance up when the turn signal is
on, so that the flasher won't flash very quickly.
I confirmed the resistor was blown as I tested the circuit with a multimeter
and it indicated an infinite load (open circuit). I tested the good bulb (with
the unblown resistor) and got an ohm load."
What could be the problem? Other people on the forum said these work fine.
Old Dec 22, 2002
CarbonFly's Avatar
This is the problem
Old Dec 22, 2002
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
Man I have some blue 7443 APC lights. They were a bright *** blue when i first put them in and now they have turned green....yep green. WTF!!!??? Maybe I'll see if the speed shop in town is having a sale after christmas or something and buy some good bulbs.
Old Dec 22, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
you all need to start getting your l.e.d.'s here HZ Engineering they are awesome!
Old Dec 22, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
I think sometimes if you put the bulb in and it doesn't work... you need to take it out and turn in around and put it back in
Old Dec 22, 2002
RSXtypeIvtec's Avatar
Su Mo
where did you get your led's from??
Old Dec 22, 2002
dragoon's Avatar
strange, there's absolutely nothing wrong with mine and i've had them a good 6 months.
eorlando1
May 17, 2015 11:16 AM
ORskier
May 3, 2015 12:54 PM
Readypro
May 2, 2015 12:23 AM
Bigdaddy198
Apr 30, 2015 08:36 PM
blackbullet
Dec 1, 2001 03:44 PM
