Sponsored by:
Sponsored by: CARiD
any answers about oem alarm?...can't find any
Old Dec 14, 2002
vdub's Avatar
vdub is an unknown quantity at this point
I know there was some threads on this,but I can't find them. I see they are selling for about $60 right now.
Old Dec 14, 2002
CarbonFly's Avatar
So what exactly is your question?
Old Dec 14, 2002
vdub's Avatar
I just wondered what the stock alarm covers and does. Also I heard the sesitivity is touchy. Is this true?
Old Dec 14, 2002
KeNsHiN's Avatar
LEVA
i don't really like the oem it sucks go with a after market alarm
Old Dec 14, 2002
vdub's Avatar
ok. I think I see it only works with doors and trunk anyway.
Old Dec 14, 2002
flotsamm's Avatar
Whoah.. 60 bucks? Where?
I have an EX Coupe that I installed the factory alarm in myself. I paid a $169 bucks for it from the Honda dealer. The only reason I chose the factory alarm was I dont know anyone with a shop that I can trust to install an after-market alarm in, so I did it myself. It was simple, and they can print out the instructions for you at the dealer. That and I wanted something thats plug and play for installing and known to work properly. I figured if a thief wants my car bad enough there gonna get it or whats inside anyways.
The factory alarm is weak. It has no shock sensor, no optional siren hookup, no hood sensor hookup and no over-ride switch. All it basically does is make your horn beep if someone busts open the doors or trunk.
Old Dec 14, 2002
vdub's Avatar
I guess the $60 was for the 99'-00' model. My mistake,but they are $120-130 I think. Guess I'll pass on it anyway.
Old Dec 14, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
Its called cut the horn wire and your in. Hondas alarm use your factory horn whichis easy to get to from the front. Friend of mine had the oem alarm on his civic, they cut the horn wire and stole his whole stereo right from his drive way. If I was you, dont even waste your money on the factory alarm. Get a Cliffered or code alarm.
Jeff
Old Dec 15, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
Quote
[hr]The factory alarm is weak. It has no shock sensor, no optional siren hookup, no hood sensor hookup and no over-ride switch. All it basically does is make your horn beep if someone busts open the doors or trunk[hr]
that is the OEM keyless entry system ussually found standard on the EX models, not an alarm
Quote
[hr]Friend of mine had the oem alarm on his civic, they cut the horn wire and stole his whole stereo right from his drive way. [hr]
aftermarket alarm siren wire is even easier to locate then the OEM horn.. plus only the Keyless entry systems use the horn
to answer your question.. if you want a REAL alarm, you should purchase an aftermarket alarm. The dealer ussually recommends DEI (the makers of Viper, Automate, CLIFFORD, and many more).
When i purchased my Civic EX, i purchased an optional alarm system for $200 through the finance guy. The ended up selling me an Keyless Entry Add-ON alarm. Which is basicly like this... it has an alarm brain, shock sensor and siren... but it uses your keyless entry system's remote to arm and disarm. I told them that wasnt the alarm i wanted... I wanted the DEI Automate Alarm that was offered to the LX and DX models..
why?
becuase it is like this, an Automate Alarm, has multiple channels for accessories. I added the Pop Trunk Kit & DEI windows up module and had it hooked up to the Automate Alarm.
with the OEM Keyless entry controlled alarm, you wouldnt be able to Add these options at all. they do not have any extra buttons on the remote. Just the typical.. Lock, Unlock, and Panic.
My advise to you.. just get a DEI alarm.... you can add a pop trunk kit if you wish... here is the DIY.
DIY OEM Pop Trunk Latch Opener
OEM Keyless entry system.
OEM Keyless entry system controlled alarm
DEI True Alarm system
oh yeah... DEI bought out Clifford... so DEI alarms dominate almost the whole market.. you cant go wrong with DEI.
Old Dec 15, 2002
Jeff's Avatar
Let me tell you this, The horn is alot easier to find hen the alarm that I have now. If you have the oem fog lights, 2 scews and your there at the horn!
Jeff
Old Dec 15, 2002
cvc2k2's Avatar
no thief would think of taking off your OEM foglamp! LOL. plus most civic owners dont have OEM foglamps. The theif would need to cut out the plastic trim to cut the horn.. how simple.!
Old Dec 15, 2002
Wanger's Avatar
Wanger is an unknown quantity at this point
just get 10 aftermarket horns and hook them up. i think theifs like the "la ku ka ra cha" horns
civic1316
May 29, 2015 05:13 PM
Shabba
May 13, 2015 10:55 PM
Laurenhunter7
May 10, 2015 01:09 PM
MamaBear2015
May 3, 2015 02:17 PM
Linda0818
Apr 23, 2015 11:30 AM
