Sponsored by:
Sponsored by: CARiD
HP header
Old Dec 6, 2002
matches's Avatar
matches is an unknown quantity at this point
HP header
If I buy a HP 4-1 header, do i need to cut up my engine?
Just confused about it
Thanks
Old Dec 6, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
an earlier post said that hp is redesigning our header to fit without cutting.
Old Dec 6, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Yes, you will have to cut your engine in half, put the header in place, weld the engine back together, and then bolt up the header!
I lie! The HP Racing header fits most models without modification. The only exception is the EX with 5-speed tranny. If you have a manual tranny EX, then you'll have to shave a little bit of metal off of an engine mount so that the header won't rub.
Old Dec 6, 2002
djmota's Avatar
there was a thread saying that you actually don't have to cut, but unbolt the motor mount, raise the motor up a bit install the header in place then bolt back the mount.
Old Dec 6, 2002
CarbonFly's Avatar
Old Dec 6, 2002
AEMcivic's Avatar
Take it from me.....I've searched and read every freakin thread on this forum about that header.
One guy tried removing the mount and then putting it back in after the header, but he stated that he later had to shave the mount because the header was rubbing.
Old Dec 6, 2002
Mbow's Avatar
Quote
[hr]Originally posted by: bobbyd
an earlier post said that hp is redesigning our header to fit without cutting.[hr]
They have been coming out with a redesigned header since I joined this site...don't hold your breath. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 6, 2002
cwick187's Avatar
cwick187 is an unknown quantity at this point
Please!!! Trust me................I have the EX 5-speed and the mount has to be shaved. The shop that did the install thought that they could just take the whole mount out and then put the header in and everything would be fine, well they are idiots and I had to shave the mount myself because it sounded like freakin' hell when you shift. This has been run into the ground too many times!!! The ex 5 spped has to be shaved, the lx models do not.
Old Dec 6, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Actually, i pulled the mount and installed the header with no problem. It's not the mount that needs to be shaved it's the bracket the mount is held on with. You only need to shave a piece | | that big off, just so it doesn't rub. Once installed you will see the clearence issue, if you have a dremel you can grind it out in about 2 minutes. I used a hand hacksaw and it took me 10 minutes and all is fine, and the integrity of the mount was not diminished. I have posted the how to in the "DIY: finally a hp 4-1 header diy" or something like that. The writer of the DIY cut massive amounts of the mount off...there is no need for that.
Edit: Link to the thread
Old Dec 6, 2002
Roy's Avatar
Roy
Roy is an unknown quantity at this point
the structural integrity is compromised. with higher displacement engines, the mount would snap because of the torque applied. but with our engines, it's ok. but i'm still not a fan of trimming down the mount bracket.
Old Dec 7, 2002
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
That was me that posted earlier about the redesign. I called HP Racing and they said that they have stopped production and any Header/Cat that you can get is the old style that people still have in stock. They will be coming out with a new one in Feb. or so. Same HP gains but EASY INSTALL!!!
Old Dec 9, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
nope, goes right in there, get part number F120, that is the high flow cat, bolts right up to it beautifully
Old Dec 11, 2002
rino's Avatar
rino is an unknown quantity at this point
how does the 4-1 header with cat sound, I dont like the ricey high pitch sound I like the deep sound. Does it affect it in any way?
Old Dec 16, 2002
xblkcivicx's Avatar
Yes, it does add a deep rumble at WOT, nice combo with a CAI. Above 4k, WOT it sounds mean...
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
