Sponsored by:
Sponsored by: CARiD
More NX info and times...
Old Nov 19, 2002
newshus's Avatar
newshus is an unknown quantity at this point
I've had the NX "Gen X" kit since installed by them at NOPI. I've left it at 50shot wet and no more because I've seen how weak our bearings are from a co-worker running 150shot dry in a 2001 RSX base model. The bearings are now paper thin and he bent a valve. Oh well, now he has the chance to build it up.
Anyway, I also have the ClutchMasters FX-300 clutch and 6 lbs flywheel installed. My best time at the track is a 15.9 @ 94mph. You have absolutely no traction in 1st and 2nd gear!! By the time I catch ground at 6500rpms in second it's time to shift into 3rd gear and I usually catch up with whomever I'm racing at the track. I haven't had the chance to try the system out on the highway. I've been wanting to drop it into 3rd from 5th and see what happens.
By the way, for those of you who don't know 15.9 seconds is not a great time but the mph's show that if I can hook up at the line then I should be low 15's, high 14's.
And yes, with a bottle heater you get a much harder hit and more pressure from your kit. Without it, your 50shot is actually only performing at half it's worth.
Old Nov 19, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
You need some slicks man!
Old Nov 19, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
get some racing slicks.ur times will be lower
Old Nov 19, 2002
PatrickB's Avatar
PatrickB is an unknown quantity at this point
my buddy just intsall his genx kit i know what u mean about 1st and 2nd.. 3rd feels awfully weak.. what plugs are u running? retard the timing any?
thaks
Patrick
Old Nov 20, 2002
DRJ's Avatar
DRJ
DRJ is an unknown quantity at this point
Can you post your 1/8th mile time off the timeslip? I'd like to see how I compare.
EDIT: Lowering your front tire pressure to about 30psi will help with your traction.
Old Nov 20, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
If your gunna use nitrous on the highway you must really be a dumba$$, its people like you that crash and kill innocent familes, and unfortunately you'll live... get a clue.. and leave racing for the track!
Old Nov 20, 2002
Shawn02's Avatar
Shawn02 is an unknown quantity at this point
exactly....there are too many crashes like that....way too many. i can't trust ppl to use that stuff responsibly, in the right moment. Some moron would use it in traffic.
Old Nov 20, 2002
AEMcivic's Avatar
what the hell are you two bitchin about? He didn't say anything about racing people on the highway. He said he wants to check out the pick-up or acceleration from a higher speed.........as opposed to acceleration from a stand still. Yes, racing on the highway is stupid, and the people that do it are idiots. But the fact that newshus went to the track to test out his setup for the first time shows that he is more responsible than the average riceboy who hooks up naws and sprays at every red light. Why must you flame people for no reason?
Old Nov 20, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
Ditto.
My weekend car ('69 Mustang Mach 1) does mid 12 quarters but I still drive it on the street. It ain't the car or how it's built, it's the driver. As long as you use your vehicle responsibly, no problem and no flames needed.
GolNat
Nov 27, 2018 03:32 PM
Jrosa
Sep 14, 2015 08:24 PM
