Sponsored by:
Sponsored by: CARiD
Using Nitrous, any good tips?
Old Nov 9, 2002
BeefMan's Avatar
BeefMan is an unknown quantity at this point
Im getting an NX Nitrous kit installed next week and wanted some advice from anyone with experience. Maybe some dos and donts or some tips to keep my engine safe from harm so I can keep spraying for a good couple years to come. Thanks for any help.
Old Nov 9, 2002
Desi's Avatar
Desi is an unknown quantity at this point
search for the "nitrous post" by joeb16
Old Nov 9, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Don't hit the rev limiter...you'll detonate your engine. If your spraying when you hit the rev limit, it will cut your fuel supply, run you lean and probably put a rod through your block. If your worried they do sell "window" kits. the window kit will allow you to set your n2o to spray in a particular rpm window. Say you want to spray from 2k to 6500 then you set it and it will only spray when WOT from 2-6500 and then stop etc...keeps you safe if your not paying attention.
Old Nov 9, 2002
Nuts's Avatar
Nuts is an unknown quantity at this point
do not activate it in 1st or 5th gear.[IMG]i/expressions/laugh2.gif[/IMG]
Old Nov 9, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
you can run it in 1st ONLY if you have REALLY good tires...
Old Nov 9, 2002
01civ01's Avatar
01civ01 is an unknown quantity at this point
spray whenever you want, any gear, just not before 3k and don't hit redline. use at least 93 octane gas and don't do more then 50 shot.
Old Nov 9, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
Does the rev limiter work by shutting off fuel flow or by dropping cylinder ignition (ala MSD)???
Old Nov 9, 2002
nme3's Avatar
JDM wannabe
would you recommend n2o for a stock 2k1 civic?
Old Nov 9, 2002
SleeperCivic's Avatar
SleeperCivic is an unknown quantity at this point
What about an aftermarket clutch? I would guess using nitrous alot might burn it out? I would just feel alot better with one in though.
Old Nov 10, 2002
xblkcivicx's Avatar
n2o is fine on stock internals, just keep it at about a 50 shot, i've heard people spraying 75 stock but you might want a piggyback fuel controller. As for a clutch, yea you'll want a clutch. stock will work for a while, but it'll burn out quick. Plus you are going to need I/H/E to let your engine breathe. Only spraying in first would be impossible unless you had it on a remote switch. Most kits use WOT to activate the solenoid, if you go WOT in first you will tach in 1/2 second and smack the rev limiter and bye-bye block. Dont spray in 5th, it's a weak gear. Rev limit cuts the fuel flow, so if you wanted to defeat that you could chip it, make it tach to 8..9..10k.
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
crowtoo
May 11, 2015 06:50 PM
superstanko
Apr 28, 2015 04:38 AM
