Sponsored by:
Sponsored by: CARiD
Does anyone have a Random Technology cat installed?
Old Oct 10, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
I found a few posts but they don't give me any user feedback. I'm interested in buying this piece but wanted to know what others thought about it.
My research has provided the following information:
-Same configuration as OEM pipe/cat piece (i.e. proper bends/angles,fitment)
-True bolt-on (has the upper mating flange(2 holes) and the rear mating flange(3 holes)
-NO WELDING!
-Stainless steel construction
-Cat has necessary piping welded to it in order to mate with EX header. Also has the properly place hanger and both O2 bungs.
-Does not throw CEL's
-2.5" inlet with a 2" outlet
-small body rectangular box shape (supposedly does not cause any interference with OEM heat shielding)(i.e. rattling,etc.)
-$298 MSRP
WEBSITE: www.randomtechnology.com
Any additional information from those who have this piece would be much appreciated!
Thank you,
TJ
Old Oct 10, 2002
Desi's Avatar
Desi is an unknown quantity at this point
no one has it cuz it came out like 2 weeks ago. where did u get that price btw? well if u wanna be a guinea pig and be the first to try it, go for it. it seems like a good product.
Old Oct 10, 2002
3rdcivic's Avatar
I will probably end up getting it but just wanted see if I couldn't get a few opinions on it first.
The price is directly from Random Technology and is full retail. However, I found it for $270 shipped.
TJ
Old Oct 10, 2002
vino's Avatar
vino is an unknown quantity at this point
will this pass emissions if you get it?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 10, 2002
dacivic's Avatar
dacivic is an unknown quantity at this point
I think you will pass emission, but in some states your car has to have certain miles before you can replace your cat.
Old Oct 11, 2002
3rdcivic's Avatar
It's not like I'm going to call up the Dept. of Transportation or Licensing and tell them I'm getting a high flow cat.
What they don't know won't hurt em!
Old Oct 13, 2002
Steggy's Avatar
Steggy is an unknown quantity at this point
I know this isn't quite the same subject(no flaming please), but... would this mod be "useable" with a turbo-kit? Specifically, would this piece be able to withstand the heat of a turbo and what about capatability. That goes for any other high flow cat. converters. Thanks for any helpful input in advance. Brian C.
Old Oct 13, 2002
Desi's Avatar
Quote
[hr]Originally posted by: Steggy
I know this isn't quite the same subject(no flaming please), but... would this mod be "useable" with a turbo-kit? Specifically, would this piece be able to withstand the heat of a turbo and what about capatability. That goes for any other high flow cat. converters. Thanks for any helpful input in advance. Brian C.[hr]
since this an exact replica of the stock downpipe/cat, this will probably bolt-on w/ the turbo manifold. so yes it would most likely withstand the heat from the manifold. i hope that helps
Old Oct 14, 2002
Steggy's Avatar
Thanx
Old Oct 17, 2002
Erichyung's Avatar
Erichyung is an unknown quantity at this point
hey 3rdcivic, where can you buy it for 270?
Old Oct 17, 2002
Erichyung's Avatar
there's no way im payin full $300 retail price for a stinkin cat. somebody posts some websites who deals w/random tech.
Old Oct 17, 2002
CapYoda's Avatar
Escaped Convict
even non MSRP price will be pretty expensive... because this is an actual working catlytic convertor.. not some straight pipe labeled as a "high flow cat"
do u have any idea how much catalyic cost? the stock ones runs for 700-800 bucks.
Old Oct 17, 2002
Erichyung's Avatar
ok capyoda
Old Oct 17, 2002
ELaudio's Avatar
ELaudio is an unknown quantity at this point
What about accredited testing on a dyno? I mean, for $300US how much performance are you getting out of this thing?
If it's still going to pass emissions it's probably < 5hp.
If you REALLY want to improve performance replace your cat with a straight pipe! less than $50 and no restrictions. But you'd most likely get busted - exhaust that isn't passed through a cat has a certain smell. Think 1969 camaro or lawnmower!
Old Oct 17, 2002
3rdcivic's Avatar
Call up Lightning Motorsports and ask for Derek. It was something like $256 plus shipping (approx. $24)
(800) 478-0952.
TJ
Old Oct 17, 2002
Erichyung's Avatar
264 isnt that bad... does downpipe always cost that much?
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
mistermenphis22
Jul 13, 2015 04:43 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
pincookie1
May 4, 2015 12:22 PM
