Sponsored by:
Sponsored by: CARiD
sedan and coupe headlamps not the same?
Old Aug 27, 2002
wawacito's Avatar
wawacito is an unknown quantity at this point
Hey guys,
I remember reading somewhere on this forum (dont remember where & cant find it with search), that sedan headlamps and coupe headlamps are NOT interchangable. They look the same from the outside, but somekind of connector is different. Can anyone confirm or disprove this? Are they interchangeable or not?
Old Aug 27, 2002
Macker's Avatar
Macker is an unknown quantity at this point
From what Im told the two are identical. The sedan & coupe headlight unit have the same part number when you order them from Honda so Im fairly confident they are identical
Old Aug 27, 2002
Vizyun's Avatar
The Fallen Angel . . .
Vizyun is an unknown quantity at this point
That is correct, somewhat. They do appear identical on the outside. The sedan's sealant is a dark grey, not black like the coupe, and is a LOT tougher to break. The connector for the coupe will not fit a sedan headlamp w/out modification.
Old Aug 27, 2002
wawacito's Avatar
thanx vizyun. so according to you they are not interchangable (without modifications)
altho with what macker said - this doesnt make any sense.
how could it be the same part number, but have different connectors? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Aug 27, 2002
Macker's Avatar
When you purchase the headlamp you are just getting the basic unit with no bulbs or wiring loom. The lamp for the coupe & sedan are the same the only difference is the connectors on the wiring loom. I think this is why the part numbers are the same
Old Aug 27, 2002
showoff's Avatar
showoff is an unknown quantity at this point
Quote
[hr]From Macker:
From what Im told the two are identical. The sedan & coupe headlight unit have the same part number when you order them from Honda so Im fairly confident they are identical [hr]
The sedan and coupes headlights are not the same and they do not have the same part number #368551 sedan lights and #374546 coupe. the diference is the deflector shield inside the parabolic reflector. The coupes deflector sheild is "closed" type giving less glare off the high beam reflector and the sedans deflector is partially open at the bottom giving a slightly different light pattern. Newbs please don't post misinformation! [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Aug 27, 2002
rijowysock's Avatar
ThE FaMiLy SeDaN
difference is that sedan headlights have tougher sealant and 11 black clips holding casing to clear plastic, coupes have only 5 clips and different sealnt which makes it easier to clear as well... i hte clearing sedan headlights they suck.
riley
Old Aug 28, 2002
Macker's Avatar
Sorry for the mis information Showoff. The european 7th gen have the exact same headlight for both coupe & sedan. The American one must be different.
Old Aug 28, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
umm, I bought Derek's old OEM headlights off his coupe. They fit my sedan just fine. No connector incompatibility at all. I'm not sure if Derek changed anything on the connectors before I got 'em, but they just plugged right in.
I didn't compare my OEM headlights with Derek's, so I can't really say right now that the reflectors are different as showoff posted. Maybe I'll have to dig my OEM sedan lights out and take a look. Anyways, D's headlights light up the road, are cleared, and the strobes work; and that's pretty much all I care about. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
cukaracha
30
Jul 26, 2015 12:01 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
elektrø
Jul 10, 2015 02:32 PM
General 7th Gen
Jul 9, 2015 10:17 PM
Spanky4269
Jul 5, 2015 09:40 PM
