Sponsored by:
Sponsored by: CARiD
Just installed my CAI..Please answer quick!!
Old Aug 14, 2002
LuvDatCivic's Avatar
LuvDatCivic is an unknown quantity at this point
I just installed my AEM CAI arrording to the DIY. IT went well, just that my check engine light was on for the first 5 minutes after I installed it and went off. Is that just the car getting used to the new air in the engine. Also the filter is slightly touching the Transmission. Is that bad? I slid a piece of rubber inbetween the filter and the trannie do it won't touch. Is this good enough??
Old Aug 14, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
reset the ecu man!!! other than that you should be fine
Old Aug 14, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
disconnect the negative (black) cable from the battery for 10 min and then hook it back up and then start the car and let it idle for 10 min. then drive
Old Aug 14, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
i hope the rubber piece doesn't melt. i believe that it's ok for the filter to touch the tranny metal.
Old Aug 14, 2002
The rubber I used is a piece of a rubber hose from an old engine...It should be heat proof right??
Old Aug 14, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
Dbone39- reset your ecu like injencivic and 4drcivc said. and the check engine light will not appear. make sure that the sensor is plugged into your intake with the rubber gournment attached.. if it is not your check engine light will come on.
ak- the rubber filter holder won't melt. i have had mine for 8 months and detached it twice to clean it with no problems
dbone39- the stock oem breather hose that connects the intake to the head is fine an will not melt[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
[IMG]i/expressions/beer_yum.gif[/IMG]
Reverb2005
Jun 26, 2015 06:22 PM
beveragemp
May 25, 2015 07:11 PM
blacklud
Apr 13, 2015 06:15 PM
MooCoW
Nov 9, 2001 05:22 PM
