Sponsored by:
Sponsored by: CARiD
AAARRRGGGG! POS PROJECTORS! HELP!
Old Jul 30, 2002
FlexEX's Avatar
FlexEX is an unknown quantity at this point
WTF!!! I installed some new H1 bulbs in my halo projectors and then my right head light stopped working and my brights started going on real dim when I turn my lights on. I replaced the original bulbs to see if it made a difference but its the same shlt. I dont know what I did or how I am supposed to restore it to how it was. It is sooo annoying and sooo ghetto. it makes my car look like @$$ at night not to mention its illegal and replacing bulbs doesnt seem to help[IMG]i/expressions/face-icon-small-mad.gif[/IMG] if anyone knows whats going on here please help. to the rest: beware of the halo projectors, theyre real cheap! they fogged too BTW
Old Jul 30, 2002
taz757's Avatar
I dunno man. Sounds kind of fishy to me. I think you better check your wiring on those things. Could have burned something up in the wiring harness for the headlights along with the wiring harness in the car.
Old Jul 30, 2002
dragoon's Avatar
ya, sounds like u fried ur wires
Old Jul 30, 2002
Voiceofid's Avatar
End Bringer
that happened to me once, it was the fuse
Old Jul 30, 2002
FlexEX's Avatar
word! which fuse????
ok i got 2 problems
1. right headlight does not light up at all, neither does right bright
2. both left and right brights light up very dim when regular lights are on, when brights are on, the left bright shines but the right remains dim
so the right light not going on might be a fuse problem?
whats up w/ the brights going on dim w/ regular head lights? how do I fix that?
how could i have fried my wires?
thanks people!
Old Jul 30, 2002
Hedonism's Avatar
Hedonism is an unknown quantity at this point
the one for your lights
Old Jul 30, 2002
ricewashed's Avatar
ricewashed is an unknown quantity at this point
are you sure it is the fuse? Unless the brights and the lights are on different circuits, the fuse should be fine. You could have splice a wire and grounded it out. There is extra resistance that is taking up your juice. The fuse is the best part to check first anyways. If you do not which one, I advise you to consult your owners manual. They gave it to you for a reason.
Old Jul 31, 2002
VTECnique's Avatar
VTECnique is an unknown quantity at this point
flex, gimme a call or come over. i had the same prob. i can prolly fix it in like 5 min.
Old Aug 1, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
vtecnique can you say over the internet what the problem is, my friend is having the same exact problem, any direction so i can help him out, cuz his crap looks ghetto and honda wont fix it.
Old Aug 1, 2002
FlexEX's Avatar
OK my original problem was caused by a blown fuse so I replaced the fuse and my lights were fine for a day untill my fuse blew again. ive gone through four fuses since then. why do my fuses keep blowing?! everything seems ok and i dont see and wires crossing or such[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Aug 1, 2002
SpitakHye's Avatar
SpitakHye is an unknown quantity at this point
Umm, the fuses blow cuz the current is more than what the fuse can support. i recommend getting a new wiring harness, the "heavy duty" ones. They connect directly to your battery and turn on Via a Relay when the lights are turned on.
teher is also a relay which turns on EACH headlight. its located in the fuse compartment under the hood.
Old Aug 1, 2002
Voiceofid's Avatar
End Bringer
or maybe put in a new stronger fuse?
Old Aug 1, 2002
FlexEX's Avatar
ill look into those things but it seems to me that the stock fuses should work fine. they worked ok w/ the clear h1 bulbs that came w/ the projectors. im only having a problem w/ the right head light too. the left is fine
Old Aug 2, 2002
FlexEX's Avatar
OK i put a bigger fuse in and my lights were alright for a minute but then that fuse blew too eventually. WTF!?? does anybody have any clue what is happening here?
Old Aug 2, 2002
civiccowboy's Avatar
civiccowboy will become famous soon enough
is it possible that the headlight is wired wrong inside? Actually, i just looked at my projectors (which I will never put in my car, probably throww away) and noticed that the wires that go to the bulbs have a connector inline with a rubber cover over it. Check to make sure the rubber cover is covering all of the metal connections and not touching the back of the bulb housings which are metal! I will bet that this is your problem! Be sure to check it carefully. Electrical problems came be hard to solve and it usually ends up being something simple like this!
Old Aug 2, 2002
Voiceofid's Avatar
End Bringer
i am curious flex, how many sets of those rims did you sell so far?
Old Aug 2, 2002
SpitakHye's Avatar
CivicCowboy, if you're gonna throw away your projectors, i'll gladly take them off your hand [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
i also found a website that has the HIGH QUAILTY wire upgrade athttp://suvlights.tripod.com/suvlightscom/id11.html
Old Nov 29, 2004
Asteroid's Avatar
Asteroid is an unknown quantity at this point
got exact same problem I am assuming it's the relay that has to be changed, the dealership wants too much for it! From 115 to 150 canadian bucks...it's so frustrating I have to check the interior fuses.
Old Nov 29, 2004
PunkingCivic's Avatar
I need TP for my bunghole
The new harness is cheaper here: http://suvlights.tripod.com/suvlight...re-harness.htm
It is $55 Plus $8 shipping and handling via UPS Ground (1-7 days)
Here is the harness for the 9004/h4:
There was a recall on some of the civics for a headlight issue. There people that were driving and the light would just cut off. I received the recal notice in the mail when and had something replace for free at the dealer.
Are you the original owner? If so depending on the vin number of your ride it might be replaceable by honda even if you have aftermarket light. However some dealers are *** clowns!
Old Nov 29, 2004
Wolfgang5884's Avatar
Sorry to hear that. I bought TYC projectors for the added safety of not risking buying POSes. I hope its not anything major.
Old Nov 29, 2004
Asteroid's Avatar
figured out what it was!!!! Do not panic if this ever happens to anyone out there...just replace your fuse in the fuse box of the engine bay...problem solved!!
Old Dec 1, 2004
dru106's Avatar
ThE CoRRupToR
Dam this thread is like more than 2yrs old!! Hahah..... He probably doesnt even have a vic no more lol.....
Old Dec 3, 2004
Asteroid's Avatar
hey man better bump this one up before someone else posts something on that matter
wingsfan19
Oct 1, 2015 03:45 AM
carid
Jun 5, 2015 11:51 PM
ej8
Apr 13, 2015 06:36 PM
Exbauer
Apr 3, 2002 01:04 AM
Diznavis
Feb 19, 2002 12:41 PM
