Need Help with wiring up my O2 simulator
Ok my O2 simulator just arrived and it has the following wire colors:
One white with green stripe wire
One white with blue stripe wire
One white with black stripe wire
One solid black wire
One solid red wire
Now I know they have them listed somewhere on this site, but Im too lazy to go look for them. Can someone who has already installed a O2 simulator give me some help with where I have to solder these wires. Thanks.
One solid red wire
Ok, if you have or have made a test pipe which takes the place of the catylatic converter so theres no restriction on the car, but the problem with that is the ecu doesnt know where the cat went and basically goes ape sh*t and puts your check engine light on and screws with your fuel maps a little. An O2 simulator simulates the function of a catyaltic converter for the ecu and then things are supposed to be fixed. I need to know how to wire up the wires on with other wires.
Dude I told you how to hook it up in your private message, why are you asking here? If you can't figure it out from what I told you then you should have a professional do it.
I'll post it here AGAIN just in case any one else wants to know
positive/negative self explanatory
RPM wire goes by blue wire by battery under black rubber boot.
O2 sensor wire goes to o2 sensor, you have to cut it and still use the harness, the sginal wire is black. Make sure you hook the simulator to the harness black wire whre you cut it and not going back to the sensor.
TPS wire, look under hood on opposte end of throttle linkage shaft on throttle body. Look for these 3 wires 1) green/yellow 2) red/black 3)yellow/blue the TPS wire is the 2nd one in the middle the red/black.
OK thats it, I hope this helps!
5ltrdrmr
Apr 12, 2014 10:54 AM
DistinctiveBP
Mar 30, 2004 03:20 PM
XSRCivic
Jun 17, 2003 05:46 AM
zetaR
Jul 17, 2002 11:13 AM
