Sponsored by:
Sponsored by: CARiD
DC SPORTS header and HP hi-flow cat?
Old May 27, 2002
Pedrito's Avatar
Pedrito is an unknown quantity at this point
sup guys i did a search and i found out HPracing has a hi-flow cat....well if i were to get the DC sprts 4-1 header and the HP racing hi-flow cat would that work??? anyone got that set-up?? and how do you take the cat off i was trying to figure it out but their is 3 bolts on one side and it looks like a weld on the other side of the cat??? can we take off the cat w/ out cutting it off??? please help me out and let me kno thanks....
Old May 27, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Good question! I also want to know...particularly, would emissions be affected, emissions warranty voided?
Old May 27, 2002
pr0ph37's Avatar
pr0ph37 is an unknown quantity at this point
<< particularly, would emissions be affected >>
the emissions problem is not so much the emissions it self but(in maryland) it is illeagle to cange the catlitic converter if you have under 50,000 miles on your car
just go with the full hp but you might want to wait a few months and see if they fix the fitment
Old May 27, 2002
Cyclosporine's Avatar
Cyclosporine is an unknown quantity at this point
I want to know too...cause I've heard good things about HP header and I wonder if their high flow cat would be as good as I heard the header is... [IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 27, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
just so u guys know....
the HP RACE header is different from the DC Sports. it is a full header that runs all the way down below the car. the DC 4-1 is only the top section. you will not be able to bolt a DC header to the HP Cat. it will not work. secondly, the OEM honda cats are already HI FLO, so there is no need to change.
Old May 27, 2002
Mbow's Avatar
<< sup guys i did a search and i found out HPracing has a hi-flow cat....well if i were to get the DC sprts 4-1 header and the HP racing hi-flow cat would that work??? anyone got that set-up?? and how do you take the cat off i was trying to figure it out but their is 3 bolts on one side and it looks like a weld on the other side of the cat??? can we take off the cat w/ out cutting it off??? please help me out and let me kno thanks.... >>
Why not just get the hp header and high-flow cat combo. The hp replaces that whole down pipe I am pretty sure. The spot where you saw the 3 bolts is where the exhaust system connects to the downpipe. Basically, you would remove everything in front of those 3 bolts and put the hp parts in their place.
The redesigned hp header w/high-flow cat is supposed to be out very soon! I'd wait if I were you.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Tedverseti
Sep 29, 2015 05:41 PM
Luluharp
Sep 27, 2015 11:56 AM
anubis62
Sep 27, 2015 12:56 AM
