What's the problem with KONI struts??????????
Many peoples here seems to have problems with KONI struts. I will get mine on friday.!!! Konis seem to blow like OEM struts do. What's the problem???[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG][IMG]i/expressions/face-icon-small-disgusted.gif[/IMG][IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
What setting are you guys/gals putting your Koni shocks at?
I had mine at 360 degrees (from softest) front and 450 degrees in the rear and the ride was to firm/bouncy. I've taken the front down to 180 degrees and need to bring the rear down but it's a pain to adjust so I'll probably get around to it this weekend.
UMMM... I believe 360 is the firmest. So I don't know how you got it to 450. BTW, setting it on it's firmest can damage your suspension unless you're driving on some smooth roads.
How did you all install your koni's...did you go it yourself....is so..can you give me a quick summary of how you did it....and if you got a shop to do it...how much did they charge???
<< Hey Maestro, where do you buy your stuff? >>
Salut! je l'ai prends chez Allignement Fafard à St- Jean sur Richelieu.( Par la 55, l'autre bord du Richelieu)
DIY King
Quote
[hr]Originally posted by: ASIANPRIDE
How did you all install your koni's...did you go it yourself....is so..can you give me a quick summary of how you did it....and if you got a shop to do it...how much did they charge???[hr]
