Sponsored by:
Sponsored by: CARiD
fixing cigarette burn
Old Jun 18, 2010
jennaf's Avatar
jennaf is an unknown quantity at this point
I have two cigarette burn holes on the back seats of my honda and was just wondering how I should go about fixing them. Do those DIY auto repair kits work and still look good or should I just not risk wasting the 80 bucks that the kit would cost and instead just get it reupholstered? It's regular tan cloth.
Old Jun 19, 2010
Re: fixing cigarette burn
try to find a junkyard replacement. the back seat bottom just pulls off in a few seconds, and then pushes back down to lock the two hooks. very simple to change. there is no way to fix a burn spot, even if you find the exact same fabric, its not easy to cut and paste a patch of it.
Old Jul 15, 2010
dash388's Avatar
dash388 is an unknown quantity at this point
I inadvertantly poked a hole in the back seat of my 2010 Honda LX 4-door. Arghhh! Just bought a Honda replacement seat cover for $122, including tax. Popped seat up by gently pulling up both front corners, about 1 foot from each end. Once loose, I used a 10mm socket wrench to loosen the clamp behind the back center left side of the seat to free up the unit. You can replace the seat cover using hog ring pliers and hog rings, which you may have to order over the internet. I'm just getting to that stage. The dealership wanted $275 in labor to make the switch. An upholstery shop said they'd put on the new cover for $50. I'm going to give it a try on my own.
4 banger
Jun 5, 2015 01:44 AM
01CivicMike
Jan 23, 2002 07:44 PM
ZZCIVIC
Dec 28, 2001 12:33 PM
supercivic01
South
Nov 30, 2001 11:27 AM
DaPipeLayer
Nov 14, 2001 08:06 AM
