Sponsored by:
Sponsored by: CARiD
Carbon Fiber door panels and middle console?
Old Dec 6, 2009
Big Schmerm's Avatar
Big Schmerm is an unknown quantity at this point
How much would you pay to have your door panels and middle console wrapped? These pics are for reference only, they are not finished products and are only for reference. Name:  IMG_0585.jpg
Size:  357.0 KBName:  IMG_0539.jpg
Old Dec 7, 2009
508bmartin's Avatar
508bmartin is an unknown quantity at this point
Re: Carbon Fiber door panels and middle console?
Would pay quite a bit if you made a mold from the original console and just made the console carbon fiber instead of just wrapping it
Old Dec 7, 2009
Anticrime's Avatar
Anticrime is an unknown quantity at this point
hmmmmm, i'd pay anywhere between 100-200 for a quality job
Old Dec 7, 2009
yeah if its just wrapped, prolly not more than 200. you can get a full trim piece kit in cf for around 100-150 and it will look nearly the same. actually i dont think i would like a full cf piece, doesnt look right.
Old Dec 7, 2009
When I make structural peices, I make molds. But most of the people I deal with only want the carbon for its looks.
The pic is before I did any trim work so the rectangular center piece will go back in when its done, so it wont look so overdone with carbon.
Thanks for the responses.
Old Dec 7, 2009
ah okay. that would look better then. i would love a cf panel i can put in place of the moonroof glass to fill the hole, but everyone seems to think it cant be done. i guess it would be hard to make a mold since there is nothing with that exact shape, only the roof with the hole. im really wanting to take all my moonroof parts out (glass, motor, etc) and convert to a manual roof where i can just take off the panel if needed, or leave it on when it rains.
Old Dec 7, 2009
It can be done. What year is yours? Ill keep an eye out for a similar one around here and see if I can get a mold done.
Old Dec 7, 2009
its a 2002 civic EX sedan (the only model with a moonroof). actually all 01-05 civic ex comes with the same roof specs i think (04-05 might be different, but prolly not). i can double check on the model differences by cross-checking the glass part numbers. i know a few other people were interested here too. mostly because the moonroof glass and all the hardware and motors weighs over 100 lbs. if there is a way to just make a lightweight removable moonroof insert to replace the glass (not a whole roof cap cover) that can be somehow attached and waterproofed, it would still allow a manual moonroof system without all the weight.
Old Dec 7, 2009
lordhelmet's Avatar
This guy made a bolt in plug for his EP3.
http://www.ephatch.com/forum/showpos...1&postcount=35
I thought one of the vendors were working on a fiberglass or cf plug too but I can't seem to find it. I do know that those plugs did not bolt in. He used the term "rivet in" so I'm not sure thats the path anyone would want to take. Big Schmerm you should make a moonroof plug. Lots of people would be interested in it.
Old Dec 8, 2009
bah i have to sign up on ephatch. but i dont want a permanent plug.
maybe the best way would be to make a mold of the glass piece only, then reuse the oem rubber seal around the new piece and push it in so its flush with the car body, then install 4 bolts from the inside to hold it to the body or something. logistics need to be worked out on that.
i guess the idea is converting a moonroof (glass) to a sunroof like this.
Old Dec 8, 2009
lordhelmet's Avatar
The guy that I linked you to who did his plug one off had his bolted in. It looked real nice.
Old Dec 8, 2009
okay i will sign up and check it later.
Old Dec 8, 2009
As of right now my plan is to recreate the glass piece in carbon, and use the original seals. As far as attachment goes, Im going to have to get in one and do some figuring. Ive spent the last couple years working in aviation, so Im familiar with several light weight attachment processes. Rivets are light, but I can assure you that no one wants to start driving a bunch of solid rivets in their roof, pop rivets are crap and will eventually leak.
Old Dec 8, 2009
great let us know how it goes
Old Dec 16, 2009
any updates? even an aluminum version that can be painted will work, doesnt have to be cf. basically something that can replace the glass and still use the oem mounts and seals. i think that would be the easiest, and the glass is what weighs the most anyway.
GotSiR
Jun 23, 2016 04:06 PM
theteju
Aug 5, 2015 06:59 PM
muttleytm
Jul 11, 2015 06:00 PM
ballmich
Jul 9, 2015 11:59 AM
Spanky4269
Jul 5, 2015 09:40 PM
