Sponsored by:
Sponsored by: CARiD
fixing door handle that stick
Old Oct 7, 2009
soccersmitty55's Avatar
soccersmitty55 is an unknown quantity at this point
I have a 95 5th gen civic lx. when I open one of the doors, the handle from the outside sometimes doesnt pull itself back in. You have to push it back in position for the door to close. What would fixing this require? would it just be taking the plastic off the door and spraying some lube on some things or could I have to replace some spring or mechanism? I am getting the car ready to sell, and I would like to fix this if it wouldn't be too hard. However, I won't fix it if it means putting a bunch more money into the car or a ton of work.
Old Oct 7, 2009
Re: fixing door handle that stick
try to spray silicone lube in the side of the door where the latch mechanism is.
Old Oct 7, 2009
I sprayed some WD-40 already and that didnt do much. Is that considered a silicone lube? Would this hinge most likely be the source of resistance keeping my door handle from from pulling closed?
Old Oct 7, 2009
possibly yeah. try the silicone spray. wd40 is useless
Old Nov 8, 2009
skyscrarag's Avatar
skyscrarag is an unknown quantity at this point
Very good Elpie. Thanks for the smile. I think the Open Source is my favorite, but all the others are so good also.
vgon24
May 12, 2015 09:16 PM
ROBREALZCIVIC
Dec 19, 2001 06:57 PM
Cypher
Dec 15, 2001 07:25 PM
rallyred2k1civic
Dec 8, 2001 11:49 AM
CivicHX01
Nov 2, 2001 08:49 PM
