Sponsored by:
Sponsored by: CARiD
Projector Problem
Old Apr 13, 2002
cro2k2civicla's Avatar
cro2k2civicla is an unknown quantity at this point
Projector Problem
I have recently installed projectors on my vehicle. I bought them at NOPI auto parts and They are made by CK and are Chrome/Clear not Ion Blue. I put in some PIAA Xtreme white bulbs in which the driver side is noticably blue in color and the passenger side is a bright white. It looks odd to see at night. I tried new bulbs and same effect. Also the passenger side seems to be dimmer. I have had them aligned and no help there either. Is there a different bulb I can try that would be blue like I want, ie Razo? Or how can I fix the problem?
Old Apr 13, 2002
Voiceofid's Avatar
End Bringer
sounds liek it's still the housing's problem, mine is the same, one side is bright white, and the other is yellow(oem bulbs)
Old Apr 13, 2002
Is there any other bulbs that I could try that would equal it out? Darker blue bulbs perhaps?
Old Apr 13, 2002
Bartkat's Avatar
You might try Sylvania Cool Blue. I like them better than the extremes and they light up the road better. They look blue to look at them, but they light the road white. They are also available at many parts stores and are relatively inexpensive. I think their equivalent to H4 id 9003.
Old Apr 13, 2002
Do they make them in H3 format?
Old Apr 13, 2002
Bartkat's Avatar
I don't know the H3 equivalent, but you can look it up here.
SYLVANIA COOL BLUE. WHITE HOT. SUPER COOL. 100% STREET LEGAL *
Old Apr 14, 2002
Cristo's Avatar
Cristo is an unknown quantity at this point
The housing in your projectors are messed up cause you touched the bulb or something and when you turned on your headlights it burned what ever was on tha headlights and fogged up the housing ..........same thing happened to me dude
Old Apr 14, 2002
PeArlHoNdA's Avatar
PeArlHoNdA is an unknown quantity at this point
my bulbs were doin sam thing, 1 would be blue and the other would be yellow and dim...come to find out i killed the fuse on that side so there wasnt enough power gettin to the bulb. did u put the "bad" bulb into the other side and see if it shines correctly? thats how i figured i killed somethin on that side cause the boths worked great on 1 side and not the other.
PeArLhOnDa
Old Apr 14, 2002
Thats exactly what its doing, where is this fuse so i can replace it?
Old Apr 15, 2002
Bartkat's Avatar
Try the owner's manual.
carid
Jun 5, 2015 11:51 PM
Professional
Jan 6, 2002 11:42 PM
vietnam
Dec 21, 2001 02:10 PM
Hondasport01
Dec 17, 2001 01:53 PM
DaPipeLayer
Nov 14, 2001 08:06 AM
