Hond civic crank shaft
Rep Power: 226 Re: Hond civic crank shaft
if you just want to put another d series in there, just buy another motor instead of putting another crankshaft in. chances are a crankshaft isn't all you're going to need to replace, depending on what happened. save the headache! haha. seriously though i'm sure you can find a complete D-series dropout with low mileage for 400 bucks or less.
Rep Power: 0 Re: Hond civic crank shaft
Well ive found motors on ebay but the only thing that needs replaced is the crank and a rod. The person I bought it from is a dumb *** and ran it low on oil and it spun a bearing we have it apart and its in awesome shape. My two options are getting the crank turned or buying a used one its cheaper to buy a used one. Also I want to make some hp what head comb are good for a 1.6.
Im interested but is it as simple as that or do you have to change things for clearance or is it direct swap. How much do you want for it.
Blaster30
04-22-2015 12:21 PM
