Sponsored by:
Sponsored by: CARiD
more HP racing header problems
Old Mar 24, 2002
rac53041's Avatar
rac53041 is an unknown quantity at this point
I installed the header the other day(pain in the butt) and now my idle is very rough I reset the computer
adjusted throttle cable same problem also my check engine light came on don't know if the light is related will check it out tomorrow , anyone else have the problem with the idle
Old Mar 24, 2002
RedDragon333's Avatar
iits the header....a lot of problems have been arising from that header
Old Mar 25, 2002
VROOM's Avatar
VROOM is an unknown quantity at this point
I'm having problems too. 1st of all I had to cut a piece off my to make the header fit. I installed the header and high-flow cat. My engine light went on. 1 month later still won't go off. I reset the computer, bought new o2 sensors, changed the position of the sensor and still nothing. I called hp racing and they told me that this problem has only happened to me. somebody help! [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Mar 25, 2002
Bartkat's Avatar
Somebody sells an O2 simulator that sends a fake signal to the sensor and keeps the light from coming on.
Old Mar 25, 2002
Mbow's Avatar
Aren't there 2 sensors, one before the cat and one after? hmmm...I have read about installation problems but nothing about the check engine light. Can you give some specific details about the installation.
Old Mar 25, 2002
VROOM's Avatar
[IMG]i/expressions/face-icon-small-mad.gif[/IMG] 1st I removed stock heaader and cat. next when I was trying to install the header, a piece of the motor mount was in the way so i cut a small piece off so everything would fit. the thing w/ the o2 sensor is that there are 2 spots on the header where you can put the sensor. I moved the sensor from the lower opening to the upper and used the supplied cap for the lower one. I reset the comp again and after a bit of highway driving , the light lit up again. just to rule out the sensors, I bought 2 new ons and installed them . reset the comp, and still the engine light returned. I 've contacted hp racing and they said I'm the only one to come out and contact them. By the way, their toll-free # is 1800-522-7855. I'm dealing w/ Frank. I must say that Frank is being very good abuot trying to resolve this problem. But I'm starting to get a littlr frustrated.
Old Mar 25, 2002
VROOM's Avatar
<< [IMG]i/expressions/face-icon-small-mad.gif[/IMG] 1st I removed stock heaader and cat. next when I was trying to install the header, a piece of the motor mount was in the way so i cut a small piece off so everything would fit. the thing w/ the o2 sensor is that there are 2 spots on the header where you can put the sensor. I moved the sensor from the lower opening to the upper and used the supplied cap for the lower one. I reset the comp again and after a bit of highway driving , the light lit up again. just to rule out the sensors, I bought 2 new ons and installed them . reset the comp, and still the engine light returned. I 've contacted hp racing and they said I'm the only one to come out and contact them. By the way, their toll-free # is 1800-522-7855. I'm dealing w/ Frank. I must say that Frank is being very good abuot trying to resolve this problem. But I'm starting to get a littlr frustrated. >>
also he told me about a chip that will make the engine think that it is ok w/ o2 readings
Old Mar 25, 2002
rac53041's Avatar
I checked my car out this afternoon at work I fixed the vibration the header was rubbing a bracket on the subframe so I just bent the bracket a bit the engine light was a catalyst deteriation code the high flow cat doesn't work as good as the stock cat I reset the light and it didn't come back on os hopefully it was an intermittant thing
Old Mar 25, 2002
VROOM's Avatar
hopfully it will stay off. usually it takes a bit of driving then it goes on. w/b to keep me updated.
Old Mar 25, 2002
Mbow's Avatar
So, how is the performance? Is it noticeable? Did your exhaust get louder or what?
Old Mar 26, 2002
01EXtc's Avatar
01EXtc is an unknown quantity at this point
i havent had the first sign of trouble with my HP header
Old Mar 27, 2002
Mbow's Avatar
<< i havent had the first sign of trouble with my HP header >>
Do you have the 4-1 w/high-flow cat version? If yes, what about the darn performance??
Old Mar 27, 2002
StLVtec's Avatar
StLVtec is an unknown quantity at this point
yeah what about performance wise im thining of gettin it
Old Mar 27, 2002
rac53041's Avatar
performance wise the header is awesome there is improvement through out powerband my car is louder now also
I called HP today and talked to Rich and he said they are coming out with a computer chip that should solve the problem he said the chip will give us more horse power I think it will be simular to the venom 400
Old Mar 27, 2002
rac53041's Avatar
yester day at work I got under a LX auto civic and it has a differnt front motor mount than my 5sp civic looks like the header was made for the automatics
Old Mar 27, 2002
Bartkat's Avatar
Lucky you didn't get busted for trying to steal the trans.
Old Mar 29, 2002
rac53041's Avatar
I work for Honda and I had it on a lift doing a oil change on it and why would I want an automatic when my car is a 5 spd
I have an update on that computer chip that hp is coming out with they say it should be out in 2-3 weeks
Old Mar 29, 2002
Bartkat's Avatar
Guess you wound't want a sense of humor either.
Old Mar 29, 2002
avenger's Avatar
avenger is an unknown quantity at this point
hehehehe now those of us who were skeptical are secretly laughin [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
hehehehe click me to see [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 29, 2002
01EXtc's Avatar
i have the 4.1 and the stock cat, bolted right on with no cutting or anything. took a floor jack to the front and jacked it up and put it on myself. performance? well it adds a lil towards shift points, id say 3.5 and up on the RPM
Old Mar 30, 2002
Mbow's Avatar
Hmmm...I have only read about fitment issues. I wish I would have bought the header now, but they didn't go low enough. You still have to mod the e-mount. I am waiting for the redesigned version before I buy one. Hopefully, someone will offer a GB then and from another distributor if we are lucky. I have never seen anyone handle a GB or business prop in such a bad and lazy way.
Old Mar 30, 2002
01EXtc's Avatar
MBOW-
are u talking about Eurotice Electronics?
Old Mar 30, 2002
O1CIVICEX's Avatar
O1CIVICEX is an unknown quantity at this point
I have the HP header with free flow cat, mid pipe, and axle back exhaust. My light recently came on. Does not hamper performance. As far as horsepower increase goes, with all three peices, very noticable. i guess I will be buying the chip they will be offering. My only main problem is that I cannot get the donut gasket to seal well where the header connects to the freeflow cat, anyone else having this problem.
Old Mar 30, 2002
Mbow's Avatar
<< MBOW-
Yep!
Old Apr 1, 2002
VROOM's Avatar
i have the enmgine light problem too hopefully the chip will fix it.
Old Apr 7, 2002
01EXtc's Avatar
chip? i dunno, i wouldnt mess with a product that makes u have to buy an ADDITIONAL piece just to make it work. im not into that, just my opinion
Old Apr 7, 2002
O1CIVICEX's Avatar
<< chip? i dunno, i wouldnt mess with a product that makes u have to buy an ADDITIONAL piece just to make it work. im not into that, just my opinion >>
Then dont buy a car, because it requires gas for it to run.
Old Apr 22, 2002
VROOM's Avatar
ha! smart thinking. IT is a good point though. but hey, i was gonna get a chip anyway. If it fixes my engine light problem, smoothens out the exhaust tone and adds hp at the same time, than its all gravy.
Old May 17, 2002
wwwEuroticElectronicscom's Avatar
wwwEuroticElectronicscom is an unknown quantity at this point
hi
check our site out at www.euroticelectronics.com www.ebaystores.com/euroticelectronics we are hp racings official dist online. we carry all hp line including the shorty chrome and ceramic header and the 4-1 chrome header with hi flow cat. we will match or beat any competetors pricing. we also offer a one year warranty for hp racing against manufacture defects. we carry anytghing and everything for cars. if you cant find it just ask and we will get it for you. thank you for your time.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Supramk3
Jun 11, 2015 11:13 AM
EK_Eddy
Jun 6, 2015 07:31 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
ChristinaVHH
May 10, 2015 03:51 PM
