Sponsored by:
Sponsored by: CARiD
Nos cost me 1800$ so far....
Old Mar 19, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-frown.gif[/IMG]Update on my stupid decision to use Nos. My friend (mechanic) called and said it looks like I bent a rod using the Nos. He says it looks like there is some wear and tear on most of the pistons and suggest replaceing all the rings, and pistons. Plus he said, somehow it looks like the head gasket kind of degenerated from so much heat. How much??? 1800$ (so far) At least it is repairable. But I should be up and running by the end of the week.
Old Mar 19, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
Can you plz give a detailed description of the kit u were using. NX, nos, Zex, was it a 50 shot, dry or wet??
--->give us the 411 [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Mar 19, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
im guessin he was using either a wet kit, or a large shot (above 50), or a combination of the two....
Old Mar 19, 2002
Sampsonite's Avatar
Sampsonite is an unknown quantity at this point
Don't feel bad. Some friggin mini-van ran me off the road and I scraped a stop sign. They kept going, I'm still saving to get it fixed, which is hard cuz i'm a student. Anyway, the estimate i got when it first happened was 2.000...Oh yeah, and a friggin intrigue slammed on their breaks in front of me for no reason like two weeks after i got my civic. That one was closer to 4.000 and my insurance flew up. GRRR! They're basing our insurance on the older civics [IMG]i/expressions/face-icon-small-mad.gif[/IMG]which younger people have a tendency to mod and wreck...HAH that shouldn't be for our civic. How much HP can we squeeze out of a stock EX engine, maybe 135. MAYBE! That's of course assuming we don't go for NOS. anyway, i just wanted to vent that.
Old Mar 19, 2002
APS's Avatar
APS
Sure....Don't do what I did. I got a good deal on a NOS 75-shot dry. That's all I did. No upgrade to fuel system or anything. I only used it twice. First time was great....car seemed different afterwards. Second time.....KABLOOEY!!!!!
Old Mar 19, 2002
Jon's Avatar
Jon
I'm sorry about your civ, that really sucks. I have to say though that somebody else on the forum (can't remember his handle, but his little icon was a hippie w/ glasses) said before he had a 75 shot and he had no problems whatsoever even though people say that amount is too much for our motor. He also said that he did the necessary performance upgrades in the engine to make it handle that much power.
From what it sounds like, you had a stock engine with 75 shot nitrous and that sounds like a definite no-can-do. no upgrades to beef up the engine and make it stronger, plus the fact you have a dry kit so maybe a factor was the lean mixture of too much nitrous and not enough fuel from the injectors. Definitely I would have suggested to replace certain parts under the hood with stronger ones so your engine could handle the sudden increases of power when you released your nitrous.
really sorry about your car bro
Old Mar 19, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
There's your problem...
You don't want to run anything above a 50 shot unless you have already done upgrades in which case it would still be risky running a 75 shot. Run 50 shots and maybe you're engine won't blow up next time....
Old Mar 19, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
nitro is dangerous if not used correctly.
at least there was not a bad accident or speeding tickets also
Old Mar 19, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
NOS is for wusses.....NOS should never be used for street use, you will only run into trouble like these guys....especially
if you are running it through a tiny little 4 cylinder SOHC engine like the 2k1 Civic engine......
Old Mar 19, 2002
Blown's Avatar
Blown is an unknown quantity at this point
Jon, The member is Delacampos.
Old Mar 19, 2002
avenger's Avatar
avenger is an unknown quantity at this point
How many bottles did you go through APS? One bottle per use? [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
j/k but how hard did you really use the 75shot of nitrous? does one use mean 15 minutes of gas-gas-gas-gas-gas ?
Old Mar 19, 2002
delacampos's Avatar
delacampos is an unknown quantity at this point
first off, how did you manage to hook up a dry kit? dry kits do not work on our civics. if it was a dry kit, then it was a faulty installation. whoever installed it didn't realize that they is no fpr vacuum line. therefore, there was no extra fuel being added when you sprayed. this make perfect sense on why your motor went the way it did. yes, it could have survived it once, but the second go around...boom!
once again let me state it for the record... i run a 75 shot. i've been doing so for 8-9 months. i have not experiencedANY problems at all. i don't want to here this **** about running more than a 50 shot is stupid. TUNING TUNING TUNING
Old Mar 19, 2002
Grey's Avatar
DIY King
Yipper skipper. Wet only. Dry = running lean. Our stock fuel system will not be able to balance out the extra oxygen with fuel. Exactly as delacampos said.
Old Mar 19, 2002
Jon's Avatar
Jon
Delacampos, can you tell me what you modified under the hood to handle your 75 shot?
Old Mar 19, 2002
2001excoupe's Avatar
2001excoupe is an unknown quantity at this point
burn it then get a rsx type s
Old Mar 19, 2002
trevor's Avatar
trevor is an unknown quantity at this point
Colder Plugs
[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
solarpunk70
Apr 12, 2016 11:43 AM
Whitexj
Sep 30, 2015 02:04 AM
Bruce2
Sep 27, 2015 08:45 PM
curaze
Sep 22, 2015 08:27 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
