Sponsored by:
Sponsored by: CARiD
apexi v-afc not working
Old Apr 1, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
connected the v-afc today, everything is correctly connected, the only thing i didnt connect is the vtec wires, pink and purple. the screen on the v-afc is not turning on, while the key is on. the afc is making some noise, not beeps but processing noise. u have to put it up to ur ear to it to hear it, the buttons light up??? anyone knows whats up with it??? screen not working, the whole thing not working...????
Old Apr 1, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
VAFC does not work on our car. You need VAFCII.
You can tune the air/fuel, but not the vtec..... on VAFC
Old Apr 1, 2006
Havok2k1's Avatar
Wicked Pissah Admin
Gtsooh
Old Apr 1, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Originally Posted by Havok2k1
Gtsooh
Bless you.
Old Apr 1, 2006
BoostedVik's Avatar
i know, thats all i need, i didnt even connect the vtec wires....
Old Apr 1, 2006
trade it for a vafcII
Old Apr 2, 2006
BoostedVik's Avatar
its been 20hours and no help. no one has an idea why the screan is not working.... this sux for me
Old Apr 2, 2006
The vafc DOES NOT work on a 2001+ civic
Old Apr 2, 2006
BoostedVik's Avatar
i think boosted got his to work...
http://www.7thgencivic.com/forums/sh...pexi+v-afc+diy
Old Apr 2, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
a vafc should still turn on even if only the power is connected... if you are using the vafc only for a/f tune then it should still work.. otherwise if you wanted to use it for the vtec you would need a few resistor parts from radio shack to make it work... u better check your wires cause it sounds like you connected something wrong...
Old Apr 2, 2006
BoostedVik's Avatar
followed boosted installation diy, the power comes on. the lights to the bottons come on but the screen does not work. the wires are all connected exept the vtec and vtm... its little weird
Old Apr 2, 2006
well.. try this.. connect ONLY the ground and positive wires.... make sure you dont connect the power..
make sure the red and orange wires are connected at 2 different points on the positive wire and not in the same place..
make sure the orange wire is closest to the ecu
make sure the black and brown wire are on the right ground wire.. if not then it could go wrong...
make sure the brown wire is closest to the ecu
i also have attached a wiring diagram of how it should be wired from my webpage server... match these up to the wiring of your ecu... if its not the same that might explain your problem....
http:/www.xproductionz.com/uploads/vafc.pdf
wire everything up except the vtec cause theres more stuff involved to it if you are using the first vafc
Old Apr 3, 2006
BoostedVik's Avatar
rep points... ^^^^
one more question, is vtm wire (blue ) required to connect
Old Apr 3, 2006
vtm not required.. its up to u if you want to connect...
so what happen?
ORskier
May 3, 2015 12:54 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
CivicPunker17
Dec 1, 2001 06:58 PM
1028CiViC
Nov 18, 2001 05:15 PM
netcbc
Nov 7, 2001 01:29 PM
