Sponsored by:
Sponsored by: CARiD
camber kit in rear what in front?
Old Feb 15, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
ok so i've read i need a camber kit in the rear but what do you use in the front to keep things straight??? plus where is the best place to buy the camber kit and whatever i need for the front.
Old Feb 15, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Another Camber kit...
Ingalls has kits for the front and the back, check out this website.
Kinda expensive though, $46 for each front, and $148 for each rear!!!!
I'm sure there are cheaper ones out there
Old Feb 15, 2002
Ben's Avatar
Ben
ok great now if i get the neuspeed sport that lowers like 1.5 which ones should i buy the 2 inch or 1 inch correction ?
Old Feb 15, 2002
AEMcivic's Avatar
Well, if you get the 2 inch, I'm pretty sure it's adjustable up to 2 inches.
that would be good for coil-overs, but since you're going with 1.5 inch drop springs you can probably save yourself some money and go with the 1 inch correction.
Old Feb 15, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
The rear camber is adjusted with new upper arms. They basically replace the stock ones with a unit that has a huge turnbuckle on it to adjust up to 3 degrees. I used the Eibach's and they went in without a hassle. Check out the www.tirerack.com page
The front is adjusted by use of a special bolt. You can use one to replace the stock bolt, and get about 1 to 1.5 degrees. Or you can use two (one on the bottom) and get more. The bolts are really cheap, but I went with the Eibach Sportlines and only needed one set for the top to adjust my camber
Old Feb 16, 2002
VanDizKo's Avatar
VanDizKo is an unknown quantity at this point
I had full camber kit for $155.00 shipped. Ingalls front(+/-2degs) and SpecProd rear (+/-4degs). I had a good deal from 2001CivicCamberKit. This is the best deal you can get to upgrade your handling performance, A MUST HAVE KIT. Just ask for Peter, he will happy to help you out. Their products are high quality and most important great service, friendly and fast shipping, I know because I own the kit.
Old Feb 16, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
Front camber is adjustable up to a point without any kit or new anything. Try it first, you may not need a kit for the front. I have a 1.25" drop in front and still have room for more. There is no way to adjust the rear without a kit however, and the turnbuckle type mentioned above work great.
Old Feb 17, 2002
EcKo2k1Ex's Avatar
EcKo2k1Ex is an unknown quantity at this point
I had progress camber on my 99 civic and it worked really go, i think im giong to wait to see if they come out with one.
Old Feb 17, 2002
2cute's Avatar
2cute is an unknown quantity at this point
On the 2k1 civic you won't need a camber kit for the front unless you have it on the ground even then the way the McPhearson struts and the layout of the car is designed makes it literally impossible for you to camber the wheels.
Old Feb 17, 2002
azn0o7's Avatar
azn0o7 is an unknown quantity at this point
i'd go with the 2" ingals rear if you ar tight on money, cause the rear will camber a lot...
Old Feb 17, 2002
NeonNights's Avatar
NeonNights is an unknown quantity at this point
I heard somewhere (somewhere on this site maybe?) that you can adjust the rear camber up to a certain point, using simple washers bought from a hardware store. Is there any truth in this? And if so, how would you do it?? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 18, 2002
AEMcivic's Avatar
I heard the same thing, but I looked and can't see any possible way that you can do it. My friend has a '97 civic and that's how he corrected his camber.
I think this is a good place to say that there is a group buy for Ingalls Camber Kits at www.GroupBuyCenter.com.
It was set up by Lightning Motorsports in Baton Rouge, LA. (Good store, I go there sometimes when I'm in Baton Rouge)
You can call them @ 1-800-478-0952 and tell them that you're interested in the Ingalls Camber Kit Group Buy.
The prices are:
Civic 2001+ Front_____+/-1 degrees_____$20
Civic 2001+ Front_____+/-2 degrees_____$39
Civic 2001+ Rear_____-2 to +4 degrees_______$118
Call now, supply is limited.
ernhole1
Dec 6, 2001 12:05 PM
andylao
Nov 9, 2001 07:36 PM
JeffSpeed21
Nov 4, 2001 10:32 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
ImmortalEX
Oct 31, 2001 10:00 PM
