Sponsored by:
Sponsored by: CARiD
Dual guage pod
Old Oct 24, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
Dual guage pod
I just recived a dual guage pod i bought from ebay. I was wondering if any one had any idea's on how to mount it i tryed 3m automotive double stick tape and it did not work. The direction's sugest drilling holes in the pod and the pillar i don't want to do that so any sugestion will help.
Old Oct 24, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
sale it and buy the dash pod.
Old Oct 24, 2005
just got that in today, going to use both. Going to get autometer phantom volt meter, oil perssure and tempature and air\fuel.
Old Oct 24, 2005
blouisgod's Avatar
Life Begins > 6800rpms
you have to drill the stock pillar and then mount the pillar on the stocker. unless you can find ones that dont require that - hard to find but they are out there.
Old Oct 24, 2005
i'll try and figure something else out, drilling will be the last option. I'de like to get both of them wraped in cf, should i buy some from ebay and do it my self or is the a Co that does it ?
Old Oct 24, 2005
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
i just jammed my pillar between the dash and used some 3m tape i hasnt fell off yet, even in florida's summer heat. and my wicked driving
Old Oct 24, 2005
i can't do that bc i allready have an aftermarket tach installed close to the dash.
Old Oct 26, 2005
leviathan18's Avatar
leviathan18 is an unknown quantity at this point
hot silicone???? perhaps it would to the trick
or you can go and ask a fiberglass shop how much it cost to make a custom one
Old Oct 26, 2005
RHCP0801's Avatar
i have a triple pillar gauge pod and i just drilled it through the stock pillar and then put some screw caps over them so u cant even notice them, click on my cardomain link below and u can see, i think it looks good.
Old Oct 26, 2005
I got it mounted, Used 3m automotive double stick tape seems to be holding good. I'll post picks soon.
Old Oct 27, 2005
Old Oct 27, 2005
RHCP0801's Avatar
whats with all the empty holes, u shouldve put them in first if it was that much of a pain in the *** to get it on, unless u can put them on without taking it off, same with the gauge cluster ones, what gauges are you gonna be putting in, i wouldnt try the oil pressure one cause i had it hooked up which took forever and then the oil light came on so i had to unhook it
Old Oct 27, 2005
Shifty's Avatar
Just a question, what gauges are you gonna be putting on? U already have 2 gauge pods on your gauge cluster....and u have an oem tach already.....
I think u are going to have to drill holes into ur pillar to run the wires cleanly.
Old Oct 27, 2005
I don't have the money to get the guages right now, But i'm gonna get autometer phantom oil pressure, volt meter, air and fuel, and maby oil temp. I'm thinking ab doing both of them in carbon fiber, but i don't know how to do it.
Old Oct 27, 2005
skipbarber's Avatar
you have to drill holes in the pillar to run the wires through it anyways. Install it and just give it to them like that when you get the CF overlay, Im sure they can integrate the pod into the pillar. It would look better that way anyways.
Old Oct 27, 2005
I donn any one who does cf work around here?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
ZoSoIV
Sep 17, 2015 07:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
Dave Brabant
Sep 10, 2015 06:48 PM
