Sponsored by:
Sponsored by: CARiD
lambo doors
Old Aug 13, 2005
kumanan's Avatar
kumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the rough
lambo doors
do you gotta roll in your fenders to put lambo doors or butterfly doors?. do i gotta re paint the fenders??
Old Aug 14, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
You will prolly have to roll your fender, but you won't have to repaint anything, unless you somehow scratch the paint.
Old Aug 14, 2005
GACivic's Avatar
GACivic is an unknown quantity at this point
Sorry this is OFFTOPIC but I'm new to civics.. What does ROLLING fenders mean? This was never mentioned in my Mustang forums.
Old Aug 14, 2005
dirtySAMURAI's Avatar
I log in from time to time
rolling your fenders means you take a baseball bat and roll the "lip" of the fender upwards so that your tires don't rub when you go low. i don't know why you would need to roll your fenders when installing lambo doors, though.
Old Aug 14, 2005
jttegx's Avatar
OMNES AD UNUM
i think he meant the front fenders where the edge of the door will more likely hit the fender when the doors go up.
but no, if you get a quality lambo door kit, most times, the door pops away from the fender from touching it.
Old Aug 15, 2005
Yea but when the hing opens up so the door can open out first to clear it may hit, most kits will say "May require rolling of fenders" you may luck out and not have to.
Old Aug 15, 2005
kumanan's Avatar
yea because my fender is moulded to my sideskirt.. i cant roll back.. what kind of lambo kits dont require fender rolling? i need to know asap plz
Old Aug 15, 2005
You could still roll your fender, just roll them enough to clear,you don't have to roll the entire way down.
Old Aug 15, 2005
kool-aid's Avatar
kool-aid is an unknown quantity at this point
Yes, you will have to cut out a section and roll the remaining part of your inner fender. The reason is because when the hinge opens vertically the fender lip will get in the way of the hinge's upward travel. It would rub and cause your fender to bow out when the door went up. So yes, you need to trim and roll the fenders. You shouldn't have to paint the fenders as they will be off the car as you install the hinges.
I would leave the install to a pro unless you are familiar with door adjustments. My Vertical Doors kit is nice because of all of the stops and adjustments that are built into the kit. The gaps are perfect and it closes like factory.
I think it would be impossible to install a lambo door kit without removing the fender. If your side skirts are molded to the fender, you are SOL. The quality of the kit has nothing to do with rolling the fender. If you saw how they worked , you would understand why the lip needs to be rolled or cut away. Remember, the doors open normally(about halfway) before they go vertical. The hinge needs room to swing out and then up to do this operation, the lip WILL get in its way.
Old Sep 9, 2005
CVCCPE's Avatar
CVCCPE is an unknown quantity at this point
Looking for quality vertical door company any suggestions?
krazykoncepts
Sep 8, 2015 09:02 PM
First Car
Sep 8, 2015 08:54 PM
Brad Andrew
Sep 8, 2015 08:22 PM
redcloud
Sep 7, 2015 01:45 PM
ballmich
Jul 9, 2015 11:59 AM
