Sponsored by:
Sponsored by: CARiD
Stock struts and coilovers, BIG NO NO
Old Jan 19, 2002
Flatlander's Avatar
Flatlander is an unknown quantity at this point
Just a little helpful advise guys, if you are planing on getting coilovers and no aftermarket struts then don't. The stock front strut needs to have that big spring to support it. I put coilovers on my car and the front struts were makeing a popping noise. I ordered the Eibach Sportlines yesterday and I hope for the best.
Old Jan 19, 2002
Bartkat's Avatar
That seems to happen a lot, also with rear shocks. The stock shocks just can't handle the load with the stiffer, lowered springs.
Old Jan 19, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
if you get ground control or coilover is better for you to get shocks..get will blew the strut..
Old Jan 19, 2002
ZZCIVIC's Avatar
ZZCIVIC is an unknown quantity at this point
Those Koni adjustable struts look cool, I would like to have the adjustment option for different driving seasons/conditions............
Old Jan 19, 2002
1028CiViC's Avatar
and stiffness too.. koni..is good too..
Old Jan 19, 2002
showoff's Avatar
showoff is an unknown quantity at this point
I had eibach prokits with my car and stock struts/shocks, then i switched to ground controls a month later i blew my right rear shock, I just got my koni adjustable yellows in last week after having them rotting in my room since christmas and all i gotta say is WOW. I aim for potholes even with my two inch drop and i don't rub, bottom out, swirve outta control and i can still whip turns like a mother. GET THE KONI's its the best investment i've ever made on my 2k1
Old Jan 19, 2002
FlexEX's Avatar
FlexEX is an unknown quantity at this point
i made it through the entire summer on my stock struts with ground controls dropped >2" with 18s and my struts are still good. learn to drive!!!
Old Jan 19, 2002
Bartkat's Avatar
How about putting Koni yellow shocks, but keeping the stock springs? Will that work ok?
:[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 19, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
I made it a couple months with my Ground Controls and stock struts, with a 2.5" drop, and didn't blow any of them. I have since replaced them with the koni's, to give me better ride quality though.
Barkat - yes, you can use the Koni's with stock springs if you want.
Old Jan 19, 2002
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
i have had my oem struts and GC CO's for almost a year w/o a problem. I don't know what u guys are doing to blow ur struts. You have to use ur haed when lowering, u can't slam with stock struts.
Old Jan 24, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
yo flex....obviously you arent aware of simple math......
when you lower a car, it reduces the travel in the suspension (especially with stock struts), and lowering sprnigs also have nicreased spring rates...
stock struts are specifically design to be used with a stock spring and a soft spring rate.....when you subject them to a constantly lowered ride they tend to bottom out, and they can not deal with the added stress of the higher rate spring rates, this is what causes the stocks and struts to start to leak and eventually just give out...
it has NOTHING to do with knowing how to drive
peace
Old Jan 24, 2002
mochopechochochi's Avatar
mochopechochochi is an unknown quantity at this point
just go with the eibach springs.
Old Jan 24, 2002
oblivious9's Avatar
oblivious9 is an unknown quantity at this point
You defintely need shocks & camber kit....so looking at $1000 at least to lower
Old Jan 24, 2002
DJNuTzSaK's Avatar
DJNuTzSaK is an unknown quantity at this point
i don't know why but my front shocks are still good but both back ones are blown...i have camber in the front but none in the back is that why??? damn shop takes forever to order the back camber kit...bastards...oh yea my drop is around 2.5 to 3 inches all around
Old Jan 24, 2002
blackbullet's Avatar
The Legend
I have had my Ground Control Coilovers for almost a year now and have had no problems. I still want to get the Koni's though.
Old Jan 25, 2002
showoff's Avatar
<< yo flex....obviously you arent aware of simple math
when you lower a car, it reduces the travel in the suspension (especially with stock struts), and lowering sprnigs also have nicreased spring rates.....
stock struts are specifically design to be used with a stock spring and a soft spring rate.....when you subject them to a constantly lowered ride they tend to bottom out, and they can not deal with the added stress of the higher rate spring rates, this is what causes the stocks and struts to start to leak and eventually just give out....
Thanks Mwwhonda. I couldn't have put it better myself. Its pretty obvious that the education level of some of these members aren't too high. Its always nice knowing that some of us still know what were talking about. I guess flex just wants to keep on driving with his stock shock's and struts if he insists its all on driving skills he must love his stock suspension that much. [IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Jan 25, 2002
TOOLOWCIVIC's Avatar
I had my ground control on for only 2 days and all of my struts blew out
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Supramk3
Jun 11, 2015 11:13 AM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
veloce
Nov 10, 2001 01:19 PM
