Sponsored by:
Sponsored by: CARiD
Koni Struts
Old Jan 6, 2002
Flatlander's Avatar
Flatlander is an unknown quantity at this point
Koni Struts
Are the Koni Struts set up like the stock ones? What I mean is, Do the front ones have the big pirch for the big srings? The reason I ask is because the Eibach lowering springs are set up like the stock ones. Big up front and little in the back. It would suck to buy the springs and them not fit on the strut.
Thanks guys
Old Jan 6, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
The Konis come with a peice that you can use to mount your stock springs on for the rears. If you have Sportlines or a Pro-Kit, they will mount on them as well. If you have Ground Controls, then you have to order an adaptor from GC to mount the rears.
The font Koni's mount inside your stock strut housing, and use the stock spring perch. So, if you have stock springs, Sporlines, Pro-Kit or Ground Controls, they mount on the stock perch.
Old Jan 6, 2002
RobearRacing's Avatar
RobearRacing is an unknown quantity at this point
0100010 is the man...
Knows his stuff..
Rob
TornActive.com
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
