Sponsored by:
Sponsored by: CARiD
Split cv boot kit...
Old Feb 9, 2005
Seabass's Avatar
Seabass is an unknown quantity at this point
Hey everyone, ok here is the story, i bought a front axle for my car cuz my cv boot got cut and i needed to replace the axle(shop said that). So i bought a axle off the net(only place i could find it) and got it but it had a very little gash in it, so i ripped the boot off and replaced it with an aftermarket split cv boot kit, anyone know if these will last or is this fix crap? Also if i took it into honda do you think that they would be able to take the thing apart and put a new stock boot on it? Thanks.
Old Feb 9, 2005
skipbarber's Avatar
split boots are fine, but they require sooner maintenance intervals. I personally wouldnt want to use them.
Old Feb 9, 2005
Seabass's Avatar
Do you think honda can put a stock boot on there or can you not take the axle apart to slip it on? And how much sooner then usual do you think i have to check them out?
P.S.I just bought an air ride so the boots gonna be moving around alot.
Old Feb 9, 2005
pon55's Avatar
Sorry, in my mind,split boots suc(. Put OEM on the axel or you'll be sorry!
Old Feb 9, 2005
Seabass's Avatar
Can they take the axle apart and put a new boot on it?
Old Feb 9, 2005
Rotarynomore's Avatar
Rotarynomore is an unknown quantity at this point
split boots
Split boots are crap, under high RPM the will spit out all the grease inside. However if you do decide to use it seal the joining dege with silicone allow it to dry for 24-48 hours before installing the axle back on the car. I also recomend you wipe both sides of the joining edges with alachol (rubbing) before applying the silicone.
Old Feb 9, 2005
pon55's Avatar
You type as god as me,heeeeeeeeeeeeeee
Yes they can replace your boots $
Old Feb 9, 2005
_Viper_'s Avatar
hey its real easy they take the ball joint off then hammer the CV apart then slap on the boot
Old Feb 9, 2005
pon55's Avatar
(edit hammer) Take apart!!
Old Feb 9, 2005
_Viper_'s Avatar
lolll
Old Feb 9, 2005
Seabass's Avatar
how do you take it apart...i was just messing with it and i cant figure it out...
Old Feb 9, 2005
_Viper_'s Avatar
where the boot is inside is the nuckle and that comes apart..Dont mess with it if you dont know what you are doing....
Just take your axle to a Rebuilder and they will put a boot on for 25 bucks...
a shop like
CV-Tech
ricer_em2
May 11, 2016 08:09 PM
bashea
Sep 15, 2015 04:59 AM
Bricoleur
Sep 9, 2015 12:23 PM
EdGasket
Aug 29, 2015 09:58 AM
exiled1
Aug 8, 2015 06:09 PM
