Sponsored by:
Sponsored by: CARiD
Who's idea was it to use double sided tape to put a kit on
Old Jan 27, 2005
  #31
OyD's Avatar
OyD
OyD is an unknown quantity at this point
Use some sort of rubbing alcohol to clean the paint surface before using the 3M tape. Thats what I did and 3 years later its still all good
Old Jan 27, 2005
  #32
AzNmiKex215's Avatar
2k1civic.com O. G.
Originally Posted by orion_squall
no, don't drill holes on the body kit for bolts...there should have some kind of mounting kit, for example a "L" shape metal plate that connects the under of the kit to the existing hole on the bumper.
Glue and tape are usually only for secondary enforcement, or perhaps they put tape on so that they don't need to hold the kit when they install the screw/bolt.
thanks
I understand that, But the only way the bodykit will hold close to the body of the car is with the tape. The bolts and screws are mandetory for the ends of the bodykits.
Example: The ends of the sideskirt will be screwed into the bottom of the fenders. IF you do not use the tape for the middle of the skirt, it wil hang out and not hug the body like it should. Tape is the only easy reversable way.
Supramk3
May 11, 2015 07:55 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
jonavin
73
Oct 4, 2004 07:18 PM
Mokushi
Nov 1, 2001 02:40 PM
ImmortalEX
Oct 31, 2001 10:00 PM
