Sponsored by:
Sponsored by: CARiD
Power steering to Manual
Old Jan 20, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Has anyone tried this?
http://www.honda-tech.com/zerothread?id=184202
Long post but in a nutshell:
Looping the rack lines with a breather to maintain pressure in the rack to make steering less stiff while removing the pump. Apparently it is a step above removing the p/s belt. It makes steering easier than just losing the belt and eliminates the parasititc draw (i.e. more power).
I have always hated the p/s since my first Honda was a 90 Civic without p/s and there is no need for it on such a small car. My belt has been off for a couple of weeks but the parking lot turns are a bit annoying.
It looks like an easy mod and just want to know if it's been attempted on a 7th Gen.
Old Jan 21, 2005
bobsagator's Avatar
I can't be the only one trying to ditch the power steering.
Old Jan 21, 2005
Zoto724's Avatar
l33t h4x0r
Zoto724 is an unknown quantity at this point
that could be cool, though i have no idea how to go about it or the ramafications on the rest of the car.
Old Jan 21, 2005
flowerpowerlove's Avatar
just breathe...
flowerpowerlove is an unknown quantity at this point
i took out my p/s totally. the pump, the lines all of it...wanted to lose the weight and the drag on the engine
Old Jan 25, 2005
bobsagator's Avatar
I guess I'll have to try this system out and let you guys know how it goes.
Old Jan 25, 2005
Jrfish007's Avatar
if you have just aken off the belt, that means you are still running through the pump, ie when you steer you are pressuizing the pumps. I have not done this on a civic, but I had a Camaro that I put a 393 strocker into, and I didn't want to bother with the p/s, so I just capped the in and out on the rack, make sure there is p/s fluid in there before you cap them though.
Old Jan 25, 2005
bobsagator's Avatar
Yeah, that's the basic idea. It loops the in and out and has a breather to help relieve some of the excess pressure. Some fluid is left in the rack to lube the seals, but they state that the less amount of fluid the easier the steering since there is left fluid to move thru the rack.
Old Jan 25, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
I am gettin ready to do a K20A2 swap and am thinking about not have P/S installed. Do you have any regrets removing your P/S?
Old Jan 26, 2005
bobsagator's Avatar
Are you planning on installing a manual rack or just not using the pump et al for the power steering rack? I've been driving around for the past couple of months with the power steering belt off and it's a bit tough to steer at low speeds (parking lots). According to the above link, looping the rack lines and installing a breather (with less fluid in the rack) eases the effort needed and allows the pump et al to be removed. It seems the whole trick is to reduce the amount of fluid contained in the rack and to allow built up pressure to escape.
It looks like an easy mod and will get rid of the power steering parasitic draw and make the steering easier.
Old Jan 26, 2005
My intent would be not to have P/S period. I am having my local tuner do the swap so they will have to determine the best way to go about it. I will mention to them the idea of looping the rack lines and installing a breather.
Old Jan 26, 2005
K20EQUIPPED's Avatar
K20EQUIPPED is an unknown quantity at this point
K20 swap without PS....man I dunno, car is front heavy after that swap...I noticed a difference in the front....Im sure it would be fine but parking lots would SUCK!
Old Jan 26, 2005
How do you think the car would act during autocrossin? Some of the turns are pretty crazy and I am wondering if I would end up regretting not having P/S.
Old Jan 26, 2005
just breathe...
i do not regret taking it out, but you have a good point about the autocrossing. I hope to do some this year and would prob. put it back in for the race...
RIPSAW
Nov 6, 2015 04:36 AM
moorebl
Aug 29, 2015 08:39 PM
silentz
Jun 17, 2015 10:21 PM
vvr210
May 31, 2015 08:02 PM
bsmiley
Apr 27, 2015 01:27 PM
