Sponsored by:
Sponsored by: CARiD
Inyectors
Old Jan 6, 2005
djpolanco's Avatar
djpolanco is an unknown quantity at this point
Inyectors
will rsx inyector fit my civic lx ????
or what inyertors will fit ???
Old Jan 7, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Yes the RSX injectors will fit with minimal modification.
Old Jan 7, 2005
robbclark1's Avatar
Retired suspension supermod.
You don't speak Spanish do you? Just for correction and not to be mean but it is INJECTOR, with a J.
http://www.7thgencivic.com/forums/sh...ight=injectors
Old Jan 7, 2005
djpolanco's Avatar
and whould it make a big diffrent and will it give me hp ?
Old Jan 7, 2005
skipbarber's Avatar
LMAO @ rob...
no, no hp with larger inyectors.
Old Jan 7, 2005
djpolanco's Avatar
so what are the injectors for if they are not gona give horse power
Old Jan 7, 2005
grindsman's Avatar
grindsman is an unknown quantity at this point
They work good for turbo setups, allowing you do get more fuel. I might be wrong but the only way you would get more hp from the injectors would be to get more air.
Old Jan 7, 2005
robbclark1's Avatar
grindsman is right, unless you are shoving massive amounts of air in there they won't do anything. What happens with turbos or larger displacement is that you get more air in there. If you don't have injectors that can handle the air then it is wasted and not as much power is received. IF you get more fuel to match the air (air/fuel ratio) then you can maximize power.
CivicMexicano
Oct 27, 2003 01:10 PM
