Sponsored by:
Sponsored by: CARiD
auto help
Old Nov 25, 2004
01civicdriver's Avatar
01civicdriver is an unknown quantity at this point
auto help
i have a 2001 civic ex sedan. i was wondering what the best thing that i could do for it to get some extra horses out of it. i dont have the money to do a swap or switch to manual. if neone could help it would be greatly appreciated.
Old Nov 25, 2004
Check out my mods in the profile. After all that and tuning, I made 100whp. Best thing you can do is maintenance and a few boltons. Change tranny fluid every 15k. Tighten throttle cable and try to keep the car lite (no heavy subs and stuff).
Old Nov 26, 2004
how much was all ur parts that u added? also did u do all the install by ur self or did u take it to a shop to do? thx for all ur help
Old Nov 26, 2004
Mostly myself, and I had a friend install the new head for cheap.
pnp head $740 +$250 install +$150 bolts and gaskets
intake $250
exhaust $350 (way too much for a rear section)
plugs $27
ground wires $30
HVS $180
vafcII $310
header $100
I know I spent too much for the little gains I got.
Old Nov 26, 2004
nindoo's Avatar
Why is my vagina bleeding?
intake $250
plugs $27
ground wires $30
HVS $180
vafcII $310
header $100
^^^^^^^^^^ Wait till you turbo that set-up or use NOS than youll see youll hard work will have paid of. BTW are you able to control the fuel mixture, is that what a VAFCII is for? Is you mixture running leaner now with your new setup or with the same richness as stock(are you able to monitor the air-fuel ratio)?
Old Nov 26, 2004
It's running better than stock, but still not ideal. The curve is flat where before it was lean in the lower rpms and rich in upper rpms. It best to have the 14.7:1 ratio for ideal combustion to get the best power. Yes the vafcII and able to adjust for it. Only gained 2whp tho from that because not many mods yet.
Old Nov 26, 2004
Red line is before tuning, blue is after.
Old Nov 26, 2004
mwvarsity65's Avatar
mwvarsity65 is an unknown quantity at this point
how much would turboing the car do for me. i dont want to spend a ton of money and only get the gains that gearbox got i want to get significant gains.
Old Nov 26, 2004
If you turbo an auto at 8psi, expect around 150whp. Then you need tranny upgrades or it's gonna break.
Old Nov 26, 2004
what all do i need for tranny upgrades and how much would all this cost
Old Nov 26, 2004
tranny cooler $50
actual race builds and torque converter $1000+?
Old Nov 26, 2004
sevenplaces's Avatar
I want a TSX!
sevenplaces is on a distinguished road
the answer is don't waste your money, you cant. Swap or turbo....thats it (well besides different car)
Old Nov 26, 2004
im thinking about turbo but how much does that cost though
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
ttamrekab
Sep 25, 2015 04:41 PM
Skunkone
Sep 24, 2015 04:38 PM
