Sponsored by:
Sponsored by: CARiD
auto shift knobs
Old Nov 14, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
auto shift *****
whats involved in changing them..
Old Nov 14, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
removing the stock automatic shift ****
Old Nov 14, 2004
againifall's Avatar
Go Team Venture!
no wonder you have so many red blocks
Old Nov 14, 2004
Blahman2's Avatar
I have so many red blocks cause when I first starting using the site I didn't know using the theft function deducted rep points. Actually at the time I had no idea what a rep point was.
Old Nov 14, 2004
dirtySAMURAI's Avatar
I log in from time to time
Two screws...I think. Then it pulls out.
Old Nov 14, 2004
DrChi's Avatar
DrChi is an unknown quantity at this point
shift ****
There's a nice thread about it. Use the search..........
Old Nov 16, 2004
againifall's Avatar
Go Team Venture!
yeah.. only 326 results for "shift ****".. so suck it up and deal with yet another thread about them..
when it comes to a/ts.. i sorta figured the whole "unscrew it.. it comes off" thing on my own... the question is... is there anything special you have to do in reguards to the "let me shift into reverse" button if you change the shift *****? ive never taken mine apart so i have no idea how it works...
Old Nov 17, 2004
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
I have the Razo shifter for my Auto.
1) With my Razo shifter you push down in order to shift from park to reverse and from reverse to drive. Once in drive you just slap the shifter in between N, D, D3, D2.
2) The push button(stock) pushes down on the shift rod. So to answer your question NO you do not need to mod anything.
Old Nov 17, 2004
Peasey's Avatar
Peasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to behold
take the two black screws off, then romove the shifter, then put new **** over top but just let it gently rest on the white push mechanism..then apply the new restraints....make sure the white mechanism is not applied down at all when you are putting the new **** over top...your car will not be able to shift if its not on properly
Old Nov 17, 2004
againifall's Avatar
Go Team Venture!
(tanks)
Old Nov 17, 2004
againifall's Avatar
Go Team Venture!
"Ractive automatic shift ***** are designed to work on automatic transmission cars and trucks only that do NOT have an electronic "O/D" or shift mode button."
is the reverse button also known as a "shift mode button" or is that just another word for O/D?
Old Nov 18, 2004
02ciVike's Avatar
02ciVike is an unknown quantity at this point
Personally man I would just leave the stock *****. Autos are not designed for shifting so why try to pertend with a fancy ****. IMO
Old Nov 18, 2004
CivicRocker02's Avatar
I usually put a cucumber in my bum when I jerk off!
CivicRocker02 is an unknown quantity at this point
cause its pretty silly foot
Old Nov 18, 2004
ummmm back to my math hw...... lol logarithms suck puter... acutally their prety easy...
Old Nov 21, 2004
againifall's Avatar
Go Team Venture!
my stock one is getting all faded and crappy looking cuz i put my hand on it when im driving..
Old Nov 21, 2004
gotti's Avatar
^ O/d is something different. Its very easy. Just put the new **** on and make sure that you let it rest on the reverse button thing. Don't push down on it, or else it wont lock. Just set the **** on top, and tighten it down. Just play around with it, you'll figure out what is right and wrong.
Old Nov 21, 2004
againifall's Avatar
Go Team Venture!
thank you gotti yer my super lover
Old Nov 29, 2004
mjmacky's Avatar
mjmacky is an unknown quantity at this point
I bought one of those shifters once... except the holes kept getting deeper and deeper in the generic rubber piece they wanted me to screw the new shift **** into. I'm 99.9999% certain I installed it correctly, but after time it gets loose and i had to take the tiny allen wrench to tighten it up again.
Eventually I tossed it in the trash, I keep my stock stuff in a box.... labeled "Stock Honda Stuff". I want to do my entire exhaust system now, but how will I fit the old stuff in the stock box? Not your concern
Old Nov 29, 2004
mjmacky's Avatar
Oh yeah, I was writing that message and got distracted to the point where I forgot why I was posting in the first place. I wanted to ask anyone if they found any aftermarket auto shift ***** that bolt into the same 2 screw holes as our civics?
Old Nov 30, 2004
againifall's Avatar
Go Team Venture!
cardomaine.com has a few for autos.. the screw thing sounds like its the only problem.. so im guessing a lil loctite would do the trick.. or even a drop of silicone so that you could take if off without the rist of stripping the lil screw/hex/whatever
Old Nov 30, 2004
fuzzylogic426's Avatar
fuzzylogic426 is an unknown quantity at this point
you could get the spoon one (i posted some pix before). it comes with a screw/hex thingy (whatever its called). it doesnt fit into either of the two holes, but its still a good fit.
i got the spoon shiftknob and the trim piece. yep, i love to fake the funk
juror
Suspension DIY
Jul 30, 2019 03:28 AM
mark1974
Jul 28, 2015 08:18 PM
beeemerdude
Jul 23, 2015 03:53 PM
estes53
Jul 20, 2015 10:43 PM
Jul 12, 2015 11:54 AM
