Sponsored by:
Sponsored by: CARiD
shift boot install?
Old Nov 4, 2004
Deception2k1civic's Avatar
My car is goin to have a new look!!!
Deception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura about
shift boot install?
anyone got a link on how to do it? i gotta change my boot asap. need pics on how to install my momo boot.
Old Nov 4, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
I won't be able to explain this all in 1 post because I'm gonna forget something but here's the basic deal. Take the console apart and get it out of the car. (2 poppers in the front, 2 screws in the back, pull up on the e-brake panel then 2 more screws in the center under the panel. Flip the console over and unscrew the shifter trim plate. Then unscrew the trim ring and pull the staples out. Put the stock boot inside the Momo one then trace the tangs onto the leather boot, leave a little extra on the ends. Take a SHARP Xacto knife and cut the tang pattern into the Momo boot. If you care about where the momo logo sits when you're done, then pay attention to where it is when you mark and cut. Once you have the tangs cut in, use a taped over flat head screwdriver and push them back into the shifter trim, and put the trim ring back over. The leather is thick enough that it will stay in place without staples, so just screw the console back together and be done. If you got the MOMO boot that screws to the momo ****... put the boot over the lever without screwing it down, then put the **** on, then screw the 2 together, then you gotta do the 6 screws from down below. Its a PITA, but its the only way.
Old Nov 4, 2004
sounds good thanx for the help
Old Nov 4, 2004
devilvtec's Avatar
devilvtec is an unknown quantity at this point
Check the DIY section
Old Nov 4, 2004
CivicRocker02's Avatar
I usually put a cucumber in my bum when I jerk off!
CivicRocker02 is an unknown quantity at this point
http://www.7thgencivic.com/forums/sh...d.php?t=155298 Heres a link to the DIY hope that helps!
97-DX-Lover
Jun 14, 2015 06:07 PM
Jigee
May 9, 2015 11:18 AM
toastyghosty
37
Jun 10, 2002 01:07 AM
toastyghosty
32
Dec 26, 2001 02:03 AM
RedDragon333
Nov 20, 2001 11:24 PM
