Sponsored by:
Sponsored by: CARiD
Tranny Fluid Cooler REVIEW
Old Oct 29, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
i wasnt sure how to post a review into review section someone do me the favor:
Product:HAYDEN automotive transaver transmission-cooler
17000GVW
website: www.bulkpart.com (http://www.bulkpart.com/Merchant2/me...tegory_Code=HC)
Price: $24.22
Shipping: $8.50
Suggested install time: 30mins
Real install time: 2 hours (not because of lack skill, read below.)
Tools needed: plyers, philips head, flat head, knife, toenail clippers.
excessive heat in transmission fluid causes transmission to shift harshly, usualy noticed on long trips. hayden transmission cooler can be mounted in 3 different locations for different affectiveness. i chose to mount mine in the very front of radiator etc. for 100% effectiveness i also chose the add-on option rather than the stand-alone option. below is my install
install:
first began by opening my box, i received box 3 days after paying for it, which i say is damn fast. box was properly wrapped and came in pefect condition. upon opening box, all supplies needed are included besides tools listed above.
removing bumper=5min with flat head and philips head screwdriver, see diy for instructions.
next when looking down engine bay in between A/c fans and tranny u will see two metal pipes coming from transmission, one's origin is the back of transmission that is the out line, and origin top of transmission is the return line. (u can also note this by turning on car for 10seconds and feeling lines the return line is much cooler.)
start by undoing the hose clamps(this was the most time consuming part for me.. took approx 1.5 hours because of lack of space and well i dont have big hands but they wouldnt fit. the hose clamps u must squeeze with approx 50lbs torque to get em loosened and then must pull em down off the oem hose.. i removed both(top going into tranny, and the hose clam on oem hose where it goes into the radiator(they say to reuse oem but.. i found better otherwise)
take this time to cool off and mess w/ tranny cooler. i grabbed the hose included and cut it directly in half (after measuring half was perfect) dip ur finger in the tranny fluid and rub on ends of the tranny cooler, it lubes it so hose goes on better. i put on both hoses and clamped them. then i grabbed the black "modified zip ties" and inserted them into the tranny cooler on ends.. top bottom (see pic black circles)on back put the stick on foampeices..(the zip tie goes thru middle) i then put the hose clamps on the hose and set it aside. snaking the hoses thru the bottom pass side of radator(between radiator and the frame)push the ends where they need to be..
clamps undone, cooler ready. remove the oem hose. WARNING: approx 5-6 ouces of fluid will leak, jack up car and work expeditely. grab a towel and push the bottom line onto radiator, then undo top and push onto the metal pipe. slide hose clamps to their desired location and then fasten tightly (25lbs torque) go over all clamps once over to assure proper tightness. once done.. i measures on my radiator "center" and put dots where i then "snaked" the "modified zip ties thru" on other side i pushed on the "corresponding end" and then searched for a tool to use that would fit in bay and cut the ends off.. TOENAIL clippers. i grabbed mine and they worked perfectly.. i snipped ends flush and the fans spin free of any interferences.
once done.. i ran engine and then checked the fluid level.. it was right in the middle of "area" on dipstick. i was suprised... but hey now i can retun that AFT fluid i bought.. even with the fluid flowing thru the cooler and hoses its still full.
once done i put bumper back on snapped a pic^^^
and took her for a ride.
average my engine temp would be in middle it now rests about 15% lower when driving. the shifting is alot smoother and doesnt "down shift on accident anymore"
anywho, for the $ spent/saved and install time i feel it was worth the money.
feel free to PM w/ questions and concerns.
thank you.
riley
Old Oct 29, 2004
Good writeup. I mounted mine in the upper left corner between condenser and radiator, so prolly isn't helping that much.
Old Oct 29, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
NICE, this is a MUST if you have an automatic, not for immediate solutions, but in the long run it will save your tranny
Old Oct 29, 2004
abmerop18's Avatar
Jam out with your clam out.
for those who wish they had an FMIC
Old Oct 29, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
abmerop do u get extra points for being a dic k
Old Oct 29, 2004
kikoy's Avatar
kikoy has a little shameless behaviour in the past
i have one on my civic too.....its mounted right before the condenser......you can see it in my link at the signature....
Old Oct 29, 2004
YS's Avatar
YS
YS is an unknown quantity at this point
here's mine ... JMO ATF Cooler
Old Oct 30, 2004
MIT's Avatar
MIT
MIT is an unknown quantity at this point
so how this thing work.....save AT tranny?
Old Oct 30, 2004
It cools some of the fluid before returning it to the auto trans. A cooler trans will last longer, because heat kills transmissions.
Old Oct 30, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
I like both yours and sock's AT coolers.. which one performs better?
Old Oct 30, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Yea they both look good guys
And I don't think he get's more point's for being a **** but who knows
Old Oct 30, 2004
CivicS's Avatar
CivicS is an unknown quantity at this point
oky, thining about getting one for my AT, any recommended brands at reasonable price.........thanks,
Old Oct 30, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
um read my reveiw!.lol cheapest one avail
Old Oct 30, 2004
steak84ss's Avatar
steak84ss will become famous soon enoughsteak84ss will become famous soon enough
Nice idea. Gets me thinkin'
SidCivic
44
Oct 12, 2017 03:39 PM
0396
May 4, 2016 07:14 AM
carid
Nov 7, 2015 01:46 AM
JetsterDajet
Aug 15, 2015 08:07 AM
honda.lioness
Aug 6, 2015 11:58 AM
