Sponsored by:
Sponsored by: CARiD
Flushing coolant..OEM or Aftermarket?
Old Aug 2, 2004
Ramones's Avatar
Ramones is an unknown quantity at this point
Question Flushing coolant..OEM or Aftermarket?
I'm planning on replacing my coolant and wonder if anyone here used the OEM stuff or aftermarket. The manual says to use the OEM one or there is a chance of corrosion, but i think that Honda is trying to get people to buy their stuff so they can make more money. Any thoughts??
Old Aug 2, 2004
OEM unless you like corrosion.
Old Aug 2, 2004
Ramones's Avatar
Is it a fact that the OEM will prevent corrosion?
Old Aug 2, 2004
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
OEM isn't a must but it's pretty darn close. It is a zero phosphate and zero silicate forumula that doesn't do funky things to your water pump or coat the insides of the engine with stuff.
Prestone green is not a good choice. Use Honda Type 1 (undiluted) or the more common Type 2 (premixed 50/50).
Old Aug 3, 2004
Ramones's Avatar
I guess I'll just get the Honda coolant..thanks guys.
Old Aug 3, 2004
dalaw's Avatar
Bone Stock!
Damn I ve been putting Prestone green stuff in all of my cars.
Old Aug 3, 2004
zachgeyer's Avatar
oem owns
Old Aug 3, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
OEM is worth the extra $
Old Aug 4, 2004
dru106's Avatar
ThE CoRRupToR
I dont think its the coolant that causes corrosion its the water u add to it. Cuz ure suppose to add half water and half coolant. Dont use tap water!!!!
Old Aug 4, 2004
Yes tap water can have stuff in it but in the US, unlike europe, we don't have water quality issues requiring high levels of phosphates. Phosphate helps minimize european water problems but we don't need the phosphate like they do.
Phosphate "coats" the engine with a pseudo plating (I don't remember the chemical name) that isn't harmful per se but it impedes heat transfer from the engine to the coolant. There are other phosphate properties but in our engines phosphate is not our friend.
The water matters but the coolant is very important. Unless you can find a phosphate and silicate free coolant it's far easier to buy Honda Type 1 or 2.
Old Aug 4, 2004
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
uh oh...i use prestone too! I always believe honda is suggesting oem stuff for making
more $$$$..........
Old Sep 19, 2004
Silver_JS5's Avatar
Silver_JS5 is an unknown quantity at this point
what about prestone lowtox???
Old Sep 19, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
OEM! It's about $20 or so for a gallon.... dont remember, bought it a while back. It came premixed.....
Coolant, brake fluid, power steering fluid.... OEM!
Old Sep 20, 2004
CivicS's Avatar
CivicS is an unknown quantity at this point
oky, what about Automatic transmission fluid? i'm goin to change mine soon.....any DIY out there,
thanks,
UltraHDGames
Jun 8, 2016 05:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
bhollie
Sep 22, 2015 11:08 PM
rnaodm
Sep 21, 2015 12:42 PM
tooly145
Sep 5, 2015 01:05 AM
