Sponsored by:
Sponsored by: CARiD
RSX seat DIY
Old Jul 21, 2004
AllEyezOnMe's Avatar
[]D [] []\/[] []D
AllEyezOnMe should not be trustedAllEyezOnMe should not be trusted
RSX seat DIY
Im having trouble installing my seats..i remember there was a DIY by Hondawerx but i cant find it..i tried to search but couldnt come up with anything...it would be great if someone can help me out.
Thanks
Old Jul 21, 2004
Mr.Modify's Avatar
what do you need help with man?!?!?!? what's os hard about it ? unbolt the 4 bolts? unplug the 2 connections under the seat.....put new seat in place ....connect both plugs....and bolt down the seats?!?!!?!? what you don't understand? make sure you unplug your battery to!
Old Jul 21, 2004
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Don't you need to drill a hole for the seats to fit?
Old Jul 21, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Thats a bit more to it than that Mr. Modify, but not much.
On the rails, you must lengthen one of the rear holes to match the seat line up. Use a drill, etc. Not too hard.
DONT FORGET TO ATTATCH THE SEAT BELT THING, I did at first cause I never thought about it...so i had to take back out the seats to install it...OOOPS.
No need to unplug your battery- I know I know, everyone says to, but no need, really.
Old Jul 21, 2004
Mr.Modify's Avatar
I already knew that......just giving a summary on it. It's like that on my Si seats.
Old Jul 21, 2004
Mr.Modify's Avatar
....one of the brackets is to short...needs to be extended. cut drill whatever...not a real big problem if you have the tools.
Old Jul 21, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
My drill bit was ****ing gone when I was done...didnt feel like looking for the right one, had to be at work in like 30 minutes and the drill bit i was using worked, LMAO...
Old Jul 21, 2004
Vinh's Avatar
i used a mallet to bang the thing in and there was no need for drilling
Old Jul 21, 2004
Mr.Modify's Avatar
i was thinking about that hahahaha.....
Old Jul 21, 2004
HyaBoosta's Avatar
hondawerx had a diy for rsx front and rear seats. not sure if it's still there. check them out
Old Jul 21, 2004
ctv's Avatar
ctv
ctv is an unknown quantity at this point
Hey guys thanks for the info
I get my new RSX seats Friday
but what about the side air bags? these have em and my stock
seats dont, are there connectors for it, or will they just not be
working
thanks
chris
Old Jul 21, 2004
Vinh's Avatar
SRS light will come on....and no one knows how to reset it w/o going to the dealer
Old Jul 21, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
working
thanks
chris
No, side airbags will not work unless you have side airbags on your civic. You will just have extra connectors.
If you need any more help, just PM me.
ELi
Old Jul 23, 2004
ctv's Avatar
ctv
well i got my rsx seats in
had to open up all the holes
the air bag light is on, should i use the stock seat belts
from the civic seats?
Old Jul 23, 2004
phatcyclist's Avatar
phatcyclist is an unknown quantity at this point
This is probably a fair amount of work, and Ive never done this before either, so I might be wrong. But what if you took the hardware off your stock seats, and just hooked them up and put them under the seats...
Old Jul 23, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
SRS is EASY to reset'
takes 2 mins and a paperclip
Old Jul 23, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
ur light wouldnt come on tho if u did it correctly
Old Jul 23, 2004
ctv's Avatar
ctv
i have a paperclip and 2 min
but it didnt work
Old Jul 23, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
did u follow directions?
keep doing until u get it right ive done it many times so im good u gotta know how to work it.lol
Old Jul 23, 2004
ctv's Avatar
ctv
what directions
Old Jul 23, 2004
SilverStreakEX's Avatar
Show me your titties, I'M RICK JAMES BITCH!!!
SilverStreakEX is an unknown quantity at this point
it was in the diy section of the site
Old Jul 23, 2004
http://www.7thgencivic.com/forums/sh...d.php?t=155251 there ya go
Old Dec 23, 2004
HEBEGEBZ's Avatar
HEBEGEBZ is an unknown quantity at this point
mark!!
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
carid
Sep 28, 2015 10:13 AM
speedlever
Sep 24, 2015 07:18 PM
PunX
Sep 23, 2015 10:45 PM
