rsx parts
Rep Power: 0 ive seen RSX coilovers on civics. Hey I have the Tein Flex for EP3 on my car. well they have been on there for almost two years. well, its past the half year, so i rounded up.
Rep Power: 0 there are a number of parts that willl fit our cars, since both are built on the same platform. The interior will bolt in with some modifying to the rear seat if you have a coupe. The rear sway bar from the type S is a direct bolt on, I would recommend buying some poly bushings though. This will make a big difference in handeling. The front is not worth it, just the rear. All other parts are not really worth it unless you plan on doing an engine swap.
Rep Power: 0 what about these.....
i wanted to buy it, but i have to do some "eyeballing" first...
http://cgi.ebay.com/ebaymotors/ws/eB...category=43951
I log in from time to time
Rep Power: 411 Xenin: if you look around at the member rides, there is a civic coupe with a type r spoiler. it takes a little bit of modification (the integra has a wider trunk/hatch), but it can and has been done.
Tim1959
06-03-2015 08:15 PM
juror
05-26-2015 06:35 PM
