Sponsored by:
Sponsored by: CARiD
oem hardware fit on R34 side?
Old Apr 1, 2004
somean2's Avatar
somean2 is an unknown quantity at this point
does anyone know if oem side hardware kit will able to mount r34 side skirt? i just order a pair of side skirt. i want to know if i need to order hardware from the dealer
thanks
Old Apr 1, 2004
kevin78's Avatar
kevin78 is an unknown quantity at this point
i'm not sure if they do or not but when you get them have them test fitted first ,, you might be better off going to a hardware store and buying some screws and some double sided 3m tape ... just remember anything from the dealership is always 2-3 times more expensive ...some of these lips and side skirts come with mounting hardware so dont rush out and get anything till you get it
Old Apr 1, 2004
somean2's Avatar
thanks. may be i will waite then
Old Apr 1, 2004
invasian's Avatar
invasian is an unknown quantity at this point
NO they wont fit unless you do extreme modifications to your sideskirts, which i doubt you will. This is so because the oem sides are made of plastic and very thin, it bolts directly on and underneath the under panel (where your jacks go--when you're jacking up your car). There maybe a little space there so it wont quite fit as good. I have the type (r/rs) sides and the oem ones wont even fit. I had to drill wholes.
Tedverseti
Apr 23, 2020 01:45 PM
Poopies
Apr 20, 2017 11:36 PM
Erndog81
Oct 31, 2015 03:01 PM
