mobil 1 synthetic oil?
Rep Power: 0 mobil 1 synthetic oil?
thinkin about switchin the oil to mobil 1 synthetic oil? about 33,000 miles on my 02 civic now, waht u think its too late or its oky? also do i needed to flush out my engine before to put that synthetic oil in there?
i check some local auto shop, but so hard to find these 5w 20 synthetic oil.....
also any DIY for oil change, thinin about doing that myself, cuz most shop charges like 50 for synthetic oil service........
one more question, so i run synthetic like couple years later, can i switch back to regular oil?
any help, thanks
any help, thanks
Rep Power: 337 always diy
just buy a filter and 4 qts of mobil 1, i put in 10w30 and it runs awesome. i switched to synthetic around 40k miles, not necessary to flush the engine.
oh i also reccomend getting fram sure drain.
good luck
good luck
A descendant of 2k1civic.com
1 Post
Rep Power: 335 Yeah I change my own oil all the time. I use the Moble 1 0W weight. It's the recommended substitue for our cars if you read the back of the container. I like how it runs. A little strange in the winter, but summer it's pretty good. I always use the Honda filter though.
Also make sure you are changing the plug washer each time. You can get that from Honda too.
I thought about the Fram thing, but decided to just forget it. .
Jap-Euro Fusion
Rep Power: 400 Well it seems everyone has their theory on oil weight....
I run 5W-30 in the summer, 0W-30 in the winter. I think you can still switch over no problem. Oil change is easy. Paying someone to do it is a waste, I bet you can probably change your own faster than they would. Undo the drain bolt, take off the filter, put on new filter, put the drain bolt back in, refill. Thats it.
Rep Power: 0 Yes, you can switch back from synthetic to regular oil as many times as you want and it will not effect the car except of course by using regular oil you do not reap the benefits of the syntec blend.
i buy my mobile 1 at wal-mart... 5w-20... $5.00 a qt though!
so if i want to change oil, so i needed to warm up the car first before drail the oil out right? also some peps said that our oil filter is hard to reach is that true?
Jap-Euro Fusion
Rep Power: 400 Originally posted by MIT
i'm looking to change mine also, but not many 5w-20 synthetic out there? i belived like royal purple, armsoil........any mobil 1?
The best thing that you can do for your car is having a regular oil change. For people that drives a lot and mostly city driving I would recommend every 5,000km to 8,000km. This is more often than what is recommended by Honda but it is better to change oil more often. It is never too late to change to synthetic oil. You can always go back to regular oil. You don’t need to flush your oil every time you do your oil change. But it is a good idea to flush your oil before winter and after winter. This is for people who live in extreme cooled weather (-10 and up). In extreme cooled weather you will have to use a 0w 30 or 0w 20 oil. If you live in Vancouver Canada where winter is only like -5. You can use a 5w 30 or 5w 20 oil. It is not recommended to run 10w 30 because it is too thick. Yes some people run 10w 30 and they say their car runs great. Me personally I run mobile 1 synthetic 5w 30 for summer and winter and I use purelator filters. Don’t use fram filters or any cheap filters. They are cheap for a reason.
DIY on changing oil
You will need
1 floor jack it is faster this way, but if your car is lowered you have to use the jack that came with our cars.
2 jack stand
1 cardboard or creeper
1 oil drain container
1 oil filter remover that fit our oil filter
This is how I do my oil change some people will do it differently
1. Run the car for 10 min and turn off
2. Jack the car up and use jack stands for safety
3. Put oil drain container under oil pan drain bolt.
4. Remove oil pan drain bolt and washer. Use some rubber gloves because oil will be hot.
5. Unscrew oil filter 360 degrees to drain remaining oil from filter.
6. After all the oil is drained from the filter remove oil filter make sure to remove oil filter and rubber seal.
7. Install new oil filter hand tight and put some oil on the rubber seal.
8. Install drain bolt and washer
9. fill it up with oil on our cars it will take 3.79L estimate
10. Turn on the car for 30sec do not rev the engine
11. Check for oil level on the dip stick add if needed
DIY on changing oil
You will need
2 jack stand
Rep Power: 0 Originally posted by TypeRCivicBoi19
brags
46
01-07-2016 09:39 PM
07-12-2015 11:54 AM
