Sponsored by:
Sponsored by: CARiD
Have a Question and Need Help
Old Jan 24, 2004
sawgunner06's Avatar
sawgunner06 is an unknown quantity at this point
I am about to innstall a kamakaze header onto my lx. I noticed that it did not come with a head gasket. Can I use the the one from the stock header. Or was I suposed to get a new one
Old Jan 24, 2004
Help anyone
Old Jan 24, 2004
Pharoh's Avatar
Bobaganoosh!
You can reuse the stock on I beleive, just check fittment first.
Old Jan 24, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
Well its possible for you to use the old gasket but you might run into problems like leaks, So I reconmend you go to the dealership and just pick up one, once a gasket is use its not the same anymore, so go with a new.
Old Jan 24, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
use the old gasket save ya money
Old Jan 24, 2004
streetglower's Avatar
I say buy a new one just in case
Old Jan 24, 2004
importuner86's Avatar
importuner86 is an unknown quantity at this point
i used my old 1 when i got a header it works fine for now but ya might as well get a new one just to be safe
Old Jan 24, 2004
l00pb4k's Avatar
But it's a Dry Heat
l00pb4k is an unknown quantity at this point
spring for the new gasket, you never want to use the old one. Basic rule of engine building, you never want to re-use gaskets. That way you are not wondering when/if they are going to leak on you. If you don't want to buy one from the dealership, Checker sells gasket material, you can cut your own.
Old Jan 24, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
they are 3.25 from the dealership GET ONE!
Tedverseti
Apr 23, 2020 01:45 PM
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
