Sponsored by:
Sponsored by: CARiD
rear window tint problem (searched)
Old Jan 4, 2004
VellVic's Avatar
VellVic is an unknown quantity at this point
i just got my windows tinted and the tint guy didn't cover the antenna area (dots) on my rear window. He told me it wouldn't stick and by morning i would find the tint on the floor if he did cover it. So basically, when it's sunny outside, i would have a horizontal strip of sunlight coming through my back window. Is this usual or should I take it back to the tint shop and tell him to cover it or redo it? What are your opinions? Thanks.
Old Jan 4, 2004
slicksivik's Avatar
you have to buy a vinyl strip and then put it on the dots, because the tint will not stick to the dots. the guy tinted mine but it doesn't look perfect. its micro dots that hondas have at the top of the rear window. you can try to tint it but its hard to get it over every dot. just get the vinyl strip they have online or at a store and put it over it and it should be fine.
Old Jan 4, 2004
YS's Avatar
YS
YS is an unknown quantity at this point
told them to redo it
"... a horizontal strip of sunlight coming through my back window ..." <-- not on mine
Old Jan 4, 2004
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
You have two options:
1) go back and tell the bum to redo it because i know tons of people that have their dot matrix tinted like myself and it looks fine. Any skilled tinter can do it fine.
2) go back and ask the guy to supply u with the vinyl strip that covers the dot matrix.
Your choice.
Old Jan 4, 2004
2003hondacivic's Avatar
2003hondacivic should not be trusted2003hondacivic should not be trusted2003hondacivic should not be trusted
i would make her redo it i hav emy rear window tinted and i looks fine it is over the dots
git it redone
Old Jan 4, 2004
Deamon32's Avatar
Deamon32 is an unknown quantity at this point
I got my tint done at a place called tint-plus they have been in 2 magazines for their tint, and they give u a lifetime warranty, and they had no problem covering those little dots on the back windshield, it sticks, and there are no bubbles anywhere on the windshield
Old Jan 4, 2004
newshus's Avatar
newshus is an unknown quantity at this point
If you tint over the dots and then need to remove the tint for some reason it will ruin the purpose of those dots. Don't tint over them. That is straight from 3M themselves.
Old Jan 4, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
what are the dots exactly?
Old Jan 4, 2004
fine02civicgurl's Avatar
*BoY*CaR* *GiRL*DRivER*
fine02civicgurl is an unknown quantity at this point
mine are done right w/no mention of it.... so it CAN be done... now its a question if he has a business attitude to do the right thing or be a bum like he appears to be
Old Jan 4, 2004
rckdrmr's Avatar
rckdrmr is on a distinguished road
mine looks fine also. but, if you look closely you will be able to see (looking from the inside to out) some of the dots aren't ALL covered. as long as it isn't all bubbled up and the majority of the window is covered it should be ok.
Old Jan 4, 2004
rckdrmr's Avatar
those dots are actually the antenna for the radio. they've done way with the traditional ones that connect to your car.
Old Jan 4, 2004
jwalker87's Avatar
Bodacious Member
i knew that the antenna was in the rear window...but i thought it was like a wire that ran in between the two layers or something...
Old Jan 4, 2004
VTEC01's Avatar
VTEC01 is an unknown quantity at this point
Thats not true I have mine tinted on the dots and I had my windows tinted since 2001 and its never came off
Old Jan 4, 2004
white2K2EX's Avatar
I sure wish my car was newer
Yup... my dot matrix is tinted and I've had no problem in two years.
Old Jan 4, 2004
slicksivik's Avatar
let me clarify my post... my rear window is tinted over the dot matrix. been for like 8 monthes. no problems. itdoes get like an orange color tho inside which u cant see outside. i dunno what thats all about. probalby all the steam and everything in the car, lol. lets not tlak about that
Old Jan 4, 2004
Zzyzx's Avatar
Autocross Junky
Who told you that the dots were your radio antenna???
Does this person ride the small bus?
Old Jan 4, 2004
patoman32's Avatar
patoman32 is an unknown quantity at this point
those dots arnt part of the antenna. dont know what they are for but the antenna is a this wire mashed inbetween the layers of glass. you can see it in there...btw not the wires for the defroster
Old Jan 5, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
noobies first owning.. lmao..
Old Jan 5, 2004
rckdrmr's Avatar
i remember seeing this topic on clubcivic.com at one time. one guy mentioned you can mask off up to the dot matrix, and use black spray paint over it. i don't know anyone that's ever tried that though.
Old Jan 12, 2004
VellVic's Avatar
I got my rear window redone and it does look like ****. Does everyone else who got their dots tinted look like ish too?
Old Jan 12, 2004
jwalker87's Avatar
Bodacious Member
ive been asking the shop about it, and they said they can easily tint over it, or they can put a black vinyl strip over it.
It definitely isnt the antenna though. The dots are on just about every car that I've seen. Maybe they're part of the defroster? They go around the perimeter of the entire glass, though; its just thinner than at the top; maybe its for sun glare.
Old Jan 12, 2004
gizcivic's Avatar
gizcivic is an unknown quantity at this point
had mine on since 2001 no problem at all
in fack it looks factory done
Old Jan 12, 2004
Bellz's Avatar
The dots are there for different reasons.
They can be used as a fade effect on non-tinted cars.
They can be used to cut down on sun glare and let less light in and possibly cut down on heat inside the car.
But I think the main reason is to make the windows look bigger than they are. For example, on some cars when you're inside looking out, the area of the window you see isn't as big as the actual size that you see outside. Part of the window is covered up by the headline, trim pieces, etc. If the window was smaller and fit to the area you can see inside, they'd be much smaller and uglier on the outside. It's purely for looks.
And yes, the antenna is mixed in with the rear defroster, it's not the dots.
Old Jan 12, 2004
Bellz's Avatar
Okay, I'm really bored today, so I took pics to prove my last post.
Pic 1: Outside rear quarter window. Notice the dots and how they're several inches inside the outer glass.
Pic 2: Inside rear quarter. The dots show that those several inches are covering up the B pillar. If the glass actually fit the quarter window, it'd be ugly.
Pic 3: Rear window. Notice the location of dots and the really dark black area. that area is not shown inside the car.
Pic 4: Inside rear window. Again the dots show where the interior trim covers part of the window. Also notice the concentration of dots at the top of the window. This is to cut down on glare and possbily heat.
Pic 5: Passenger side rear C pillar. This is the rear defogger connection. notice the two connections. It has to be a closed circuit to work.
Pic 6: Driver side rear C pillar. This is the radio antenna, which is mixed into the rear defogger grid.
Old Jan 12, 2004
jwalker87's Avatar
Bodacious Member
jawsome...i have one question though; when i get tint, im going to have them put a stripe across the upper part of the windshield...cuz we have no tint up there, and its kinda annoying...i was thinking a band at the top, going 5 inches down at 35% tint...whatdya think
Old Jan 12, 2004
Deamon32's Avatar
when u get the stripe let me know how it looks, i know a limo tint looks pretty stupid with the stripe, but i never thought about getting a lower tint
Old Jan 12, 2004
Bellz's Avatar
I have a windshield strip on mine. It really helps with glare and looks good with the rest of the tint.
Old Jan 12, 2004
VellVic's Avatar
ok...so what about tinting those dots?...should they be or not be tinted?
Old Jan 12, 2004
Bellz's Avatar
yeah, everybody that has them tinted says they have no problems, me included. So make 'em do it right and tint the dots.
Old Jan 12, 2004
Deamon32's Avatar
Heres a pic of my tint, no problems with the dots
