Sponsored by:
Sponsored by: CARiD
What is "exhaust cut out?" eBay pics
Old Nov 2, 2003
IronFist's Avatar
Question What is "exhaust cut out?" eBay pics
Linkified
From auction:
What does this do?
The exhaust cut outs let air flow freely after the headers, therefore, acts as a straight pipe system.
It bypasses restrictive factory mufflers and resonators.
It also makes your car sound truly powerful & shockingly loud and unique.
I think it gives you a switch that you wire into your car somewhere and it lets you switch back and forth between different exhaust exits or something?
Old Nov 2, 2003
maxsin's Avatar
No Title
maxsin is an unknown quantity at this point
I think this one is a cable actuated cut out.
Old Nov 2, 2003
acidbaby's Avatar
The Beez Kneez
sounds tight i wouldnt get it im running straight pipes already
Old Nov 2, 2003
I bet it goes on right after the header and bypasses resonator and muffler. And yes, it will sound VERY loud and annoying without resonator or muffler.
Old Nov 2, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
thats what my friend has on his GSR and he has a switch so that it closes when not in use and open when he races and there is a big difference in power does his doesn't look like that
Old Nov 2, 2003
LiKEaFeRiO's Avatar
I know alot of the guys with trucks have that installed to give it a big block sound.
Old Nov 2, 2003
Dr5D's Avatar
I cant imagine that it could possible do much for our little civic
Old Nov 2, 2003
jonnyg's Avatar
E36 M3 Driver.
jonnyg is an unknown quantity at this point
a lot of old muscle car enthusists used something like that to run open headers and keep their exhaust on, infact a long long time ago my dad had a 68 chevy impala super sport with a switch on it to open the headers.
Old Nov 3, 2003
Alex1's Avatar
cheesefrog has that. but his looks better and i think his is electronic.
Old Nov 3, 2003
Alex1's Avatar
id buy it for turbo, but i need a bigger pipe. i want 2.5, i also dont like the fact that its a permanent weld on.
Old Nov 3, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Does it bypass the cat?
Old Nov 3, 2003
Jeremy's Iron
No one knows?
Old Nov 3, 2003
jonnyg's Avatar
E36 M3 Driver.
i believe its supposed to bypass all cats and exhaust and come straight off the header
Old Nov 3, 2003
abmerop18's Avatar
Jam out with your clam out.
it gives you the option to either run straight pipe, or your normal exhaust for emissions and testing. there is some lever you move in it to change the flow from the pipe to just flowing into the air. you can place it wherever you want, before the cat, in the mid pipe, or right before the exhaust. whatever fits your needs best.
Old Nov 3, 2003
LiKEaFeRiO's Avatar
From a different eBay auction. They make these for up to 3" pipes.
3 choices for installation of the cut out:
1 Straight Pipe= method recommended: It can give horsepower gain of up to 15% i.e. thats10-20HP! Installed right before the Catalytic Converter (right after the headers). This method gives you the most gain in horsepower & is quite noisy. Once the Cut Out is opened using this technique, its like running off straight pipes. But flick of the switch, and your exhaust is back to factory and no one would even know! Great for intimidating racers at red lights. Great for revving to fellow car enthusiasts.
2 No Muffler Installation: Installed right before the muffler. This will keep the exhaust from traveling out of your muffler...it will now travel out the Cut Out. This however has no potential horsepower gains but sounds mean and VERY intimidating! Once again, flick the switch and exhaust is back to normal.
3 After the Catalytic Converter Method: Installed after the Catalytic Converter. This method makes all exhaust travel through your Catalytic Converter then straight out your Cut Out. A bit quieter than the first method, but can still make interior resonance loud. Can have great potential horsepower gains as well. And flick of the switch, and your exhaust is back to factory and no one would even know!
HOW DO I USE IT?
After the easy installation, just flip the switch to the “open” position and instantly your exhaust is wide open, no backpressure, let people on the street know what you have under the hood.
Then when its time to close your exhaust up, just flip the switch back to the “closed” position and you are back to a stock exhaust.
Use the Buy it now Option and your cut out will be sent right away. No waiting.
Good luck bidding.
Old Nov 3, 2003
Voiceofid's Avatar
End Bringer
it don't sound too healthy for the passenger compartment
and with no back pressure like that, we'll probably lose power
Old Nov 3, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
but it says
Old Nov 3, 2003
Macko's Avatar
Macko is an unknown quantity at this point
Look like that brass/zinc vavlve used for natural gas lines, Hmmm same color too.... where on a car you gonna attach something this small? it has to be small cause look at the size of the TAIWAN stamp!
Old Nov 4, 2003
Voiceofid's Avatar
End Bringer
Originally posted by Bogus1
but it says
so does a intake, they claim that too, and stickers guarentee 50 hp, go get some stickers!
all cars need some back pressure, no back pressure can cause a/f mixture to go directly from the intake vale to the exhaust valve, during the overlap squence, causing less a/f mix to be burn, that's less power
most engines must retain some exhaust gas to keep the engine cool, without exhaust gas to keep the cylinder engine cold, you will get knocks, which in turn the ecm will retard timing, futher reduce power
your engine is a huge vaccum, during the intake stroke, air and fuel is pushed into the cylinder by the atmosphere, if the engine is too hot, it will actually ignite the a/f mix as it enters the cylinder, which in turn, melts are plastic pieces, your intake, and dammage other things
our engine runs ultra lean, tell me, what's the chance of THAT much exhaust comming out the the piping that we need straight pipe? i don't understand why people evn go 2.5! most 2.5 and up diameter are turbo cars, not a weedwacker 1.7 liter! for gods sake, those people with 3 inch pipes and all stock/near stock n/a are frickin retards
Old Nov 4, 2003
Whelan's Avatar
Whelan is an unknown quantity at this point
my buddy had one on his camaro. He had it so you just had to pull out the ashtray up front reach down and pull the cable to switch it back. Handy when cops are around.
mistermenphis22
Jul 13, 2015 04:43 PM
JUNITO
Jul 9, 2015 08:36 PM
1khilari
Jul 9, 2015 08:12 PM
fvckbg
Jul 7, 2015 07:08 PM
Causemo
Jul 5, 2015 06:42 AM
