Sponsored by:
Sponsored by: CARiD
Moisture sheet necessary?
Old Oct 27, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
I took out the moisture sheets in my door panels and just threw them out so I can do some dynamatting. I didn't dynamat over the big gaps that this sheet was made to protect but is it entirely needed to have them and should I really go back and buy new sheets to respread over the mat? Thanks.
Old Oct 27, 2003
FALKEN's Avatar
Civicforums Junkie
cheap trick: go to LOWE'S or HOME-DEPOT and get some plastic drop-cloth (it comes in different sizes)...then pick-up some glue...you can cut the plastic to whatever size you need and then glue it on
Old Oct 27, 2003
djmota's Avatar
they are supposed to keep water and moisture that goes passed the window scrapers out of your door and direct it to drain out. Do what FALKEN said and put them back in.
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
eebing
Sep 12, 2015 05:35 AM
Civicized
Nov 22, 2002 09:16 PM
