Sponsored by:
Sponsored by: CARiD
Rear disc conversion kits?
Old Sep 28, 2003
Whelan's Avatar
Whelan is an unknown quantity at this point
Where would I find a good one, or would it be best to go to a dealership for a 02 Civic EX.
Old Sep 28, 2003
Mr.Modify's Avatar
buy one from a SI!!
Old Sep 28, 2003
Mags's Avatar
will you make out with me
Mags is an unknown quantity at this point
02 ex? That's a drum in there chappy.
Old Sep 28, 2003
joski's Avatar
MmmMMm.. I smell boost!
joski will become famous soon enough
If you do a search, I think you'll find the stuff you need to know.. If I remember correctly, you do a conversion with the parts from an RSX. But you have to change a whole bunch of other stuff.. I don't know a whole lot about it but I know its been discussed before!
Old Sep 28, 2003
tripledoublegs's Avatar
Euro-Spec
I also want the conversion, but it's way too expensive.
Old Sep 28, 2003
RiceBuRNeR's Avatar
Turbo Member
So is there a bolt on kit at this time?
Old Sep 28, 2003
TeLLy's Avatar
Yes, it's an Acura EL
If you really want it you can order the part numbers from the rear disc assembly for an Acura 1.7EL - mine came with it stock, and you keep the bolt pattern. Drops right in, considering the minimal diff in chassis and suspension between the 1.7EL and the Civic.
Old Sep 28, 2003
Whelan's Avatar
Well for my old Saturn, to do a conversion you needed, the brake lines, calipers, rotors, wiring, and a whole bunch of other stuff and it cost like 500 just for parts.
Im surprised it doesnt come with rear disc, but oh well. Im sure there is a way to do the conversion, I am going to talk to the dealership in the next day or two to see what they have for information on it or where I could find one. My salesman was wicked cool.
Old Sep 28, 2003
RedDragon333's Avatar
you basically everything from the rear knuckle on the 02 SI. Its not a hard conversion b ut its not just bolt on. Im in the process of getting the parts i need to do it.
Old Sep 28, 2003
Aaggie77's Avatar
Aaggie77 is an unknown quantity at this point
The Type-R project car from Honda Werx has a rear disc conversion. Maybe you can ask him where he got his kit and how much it cost.
Old Sep 28, 2003
it wasnt cheap and it was a full Integra R suspension. The whole suspension usually runs around 1K and up
Old Sep 29, 2003
Kairi's Avatar
Kairi is an unknown quantity at this point
how to do a disc coversion with a civic (same way as this site, only using the exact same parts from an 02+SI/rsx)
http://www.hybridautomotive.com/tech/5lug/
note: this actually shows how to do 5-lug conversion, but essentially you're going to need the same stuff
Old Jan 4, 2007
streetthrowback's Avatar
streetthrowback should not be trusted
get a rsx type-s 5lug for like 250 and ur good, it bolts on
Old Jan 4, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Jeezus... STOP BRINGING BACK OLD THREADS
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
chrisjackson321
Jul 12, 2015 03:00 PM
OptimisticWay
Jul 10, 2015 04:31 PM
